Changing rear pads - first time on superb with EPB
Im about to change the pads on my Superb 2018. Done my own brake before on previous cars (inc Skoda), but this is my first time with a car with EPB
I have the diagnostic tool to wind back the EPB.
Do I just run diag to wind the parking brake back, and then push the pistons back (not wind in as usual?). Do both sides? Do I need to reset the EPB after changing the pads or will it self adjust?
Do I need any special tools? I think the caliper pin might be TX45? Anything else I need?
I might do the fronts as well, while Im at it, anything unusual on the superb? (what tools are needed for the front?). Do the pads come with sensor, or is it separate?
If you are using a diagnostic tool to wind back the EPB once you have changed the pads I'm fairly sure you need to use the diagnostic tool to wind out the EPB to a starting position.
