Cruise control not working - what does it take to get 'activated' in field 2 (VCDS)?
Info:
Skoda Roomster 2009
1.6 L (petrol)
VCDS: 17.8.1
Hi, everyone.
My cruise control does not work, and I've been fault-searching and eliminating usual suspects mentioned in other posts on the forum:
Brake pedal switch: works (registers in grp 066 data fields)
Brake light switch: works (registers in grp 066 data fields)
Clutch pedal switch: works (registers in grp 066 data fields)
Switch on stalk: works (registers in grp 066 data fields).
'Resume' and 'Set' buttons: (registers in grp 066 data fields).
But I've come across something that boggles my mind:
In VCDS -> 09-Cent.Elect. group 009 (Cruise Control System CCS) field #2 is says 'Not Oper.' consistently (see photo below).
What is this refering to?
What part of the CSS is not operating?
What needs to happen in order for the to get activated?
Field #1 switches between 'Not Oper.' and 'Activated' when I flip the on/off switch on the stalk.
But what the hell is field #2?
I hope some of you can enlighten me or lead in the right direction..
Best wishes and thanks,
Kasper, Copenhagen
