the truth about electric cars
@lol-lol I fear people will be lulled into a false sense of security as the battery fire problem suddenly seems not to be such a problem. This system of a special EV fire blanket is only applicable in ideal conditions.
This is not me fearmongering; I'm simply explaining real-life facts. You need to engage the old grey matter and understand that the manufacturers doing that demo had full control over the parameters; in real life, that is never going to happen like that.
Observations:
1. The whole thing was staged: location open air meaning toxic fumes are easier to disperse, flat terrain, concrete pad (non-combustible), no obstructions, cars, buildings etc, no access problem.
2. Nissan Leaf has one of the smallest batteries fitted to EVs; the battery was also highly likely to be in a very low SOC, meaning less energy to burn off.
3. Firefighters already there and fully kitted out in their BAs. In a real situation, they might have to drive miles from the fire station to the car, which could be at an event in the countryside alongside other parked cars or in an RTA on a motorway, etc. Firefighters may therefore take a considerable time to arrive at the scene. Then when they get there, they will have to assess what type of incident they are faced with, get their BAs on, get an EV fire blanket from the appliance (assuming they have one), unpack it and position it ready for deployment.  Run the hoses out and if possible, locate a hydrant to ensure they have plenty of water.
4. The fire blanket was already there, just waiting to be deployed, which is never going to be true in a real situation.
5. Because of the size of the battery and because it may have been in low SOC, it had probably already burnt off the oxidising agents by the time the blanket was deployed, with no more jets of flames being emitted sideways, flames going straight up (as a normal car fire). At that point, it was likely a normal car fire with all the plastics, carpets, seats, wiring, etc. then burning, the same as any ICE car.
6. The only time an EV presents a different hazard is with the battery; if it is actually off-gassing, it is both extremely dangerous if inhaled and can kill in seconds. If it settles on skin, then it is deadly and requires urgent hospitalisation and special treatment. It is highly explosive; the battery produces its own oxygen, so putting a fire blanket over the car does not stop it burning until the battery electrolyte has been burnt out, at which point the oxygen has been consumed, and the fire stops.
Removing the blanket allows oxygen in, and the fire starts again as a normal car fire. Water will then finish the job, as shown in the demo. Had they left the blanket on long enough, the overall temperature would have dropped to almost the same as the ambient temperature, and water might not have been required.
The EV fire blanket cannot be used in a car park because by the time the firefighters arrive, the car would be fully engulfed, as would the other cars in the surrounding parking bays, so there is no way a fire blanket could be used as it would not be possible to approach the fire as it would be too large for a blanket anyway.
EV cars being transported by road on a car carrier – again, a blanket is useless; even if able to get one over the car, the bottom would be open and oxygen has free access. EV cars on a car ship are again packed in tightly with other cars even closer than they would be in a car park. They are also strapped down to prevent movement in rough seas, so a blanket (assuming one could be dropped down from the ceiling onto the car) would NOT be able to form a sealed "chamber" to contain the fire and stop it spreading to the surrounding cars because of the straps and the shackles holding it down will create pathways for air to enter and flames/gas to escape.
As the scientists have already explained many times, if you can use a fire blanket, there is a high risk that removing it will cause a deflagration and engulf the firefighters in flames.
So to make it clear, an EV car fire of any type (hybrid or BEV) is the same as any ICE car until the traction battery decides to combust, and that is when things turn really nasty and quickly. This means that firefighters will now have to identify the type of car they are dealing with and then take the appropriate steps to tackle it.
  • Replies 12.8k
  • Views 795.9k
  • Their efficiency at any speed is more than double that of an internal combustion engined vehicle.   The improvements in aerodynamic efficiency have pretty much all been made in recent decade
  • So surely you should be welcoming Graham's interrogation of the data and news items?   There are clearly many false statements being made on both sides of the fence...   so a balanced discus
  • Latest I've seen about cause of FH fire   https://www.electrive.com/2023/08/14/it-wasnt-an-ev-that-caused-the-fremantle-highway-to-catch-fire/
Apparent low numbers of EV fires occurring in the UK from the couple of million plus registered in the UK. We are where we are. No word of a scrappage scheme yet and banning them from the roads.
Hmm, so BEV's it seems, should have some regular servicing even though the manufacturers don't seem to think so.
Observations:
You know you’re right.. totally unrealistic demonstration. It reminds me of the time I once watched a demonstration by the fire fighters of dealing with the aftermath of an RTA , and when the demo started, the FF’s already had the scene cordoned off, a hydrant located, their gear on, and the all the hydraulic gear out of the trucks and ready to go, which also obviously meant the appliances and ambulance had already arrived at the scene..
Even the people trapped in the vehicles being rescued already had their safety specs on.. so it took them mere moments to have the lid cut off the focus and the doors wedged open on the upside down vectors.
totally unrealistic compared against a real crash.
And I suspect the vehicles "involved" in the simulated RTA were pretty much normal, complete cars, and also handily spaced apart to give the FF's plenty of space to work in. Whereas in a real RTA, the cars are more likely to embed into each other, be badly twisted out of shape, etc. They may even be in a ditch or somewhere cars aren't normally found.
From reading that reply….
I think you completely missed the point I was making, through use of sarcasm.
Maybe, but still true nonetheless: all demos are always done in as near-perfect conditions as possible, never reflecting real-life situations and therefore spreading misinformation and false hopes.
@Graham Butcher what do you think that makes that video anything to do with servicing? It is a design, manufacturing or material fault. Servicing of an EV motor is not going to involve opening a motor like that. There is servicing of parts as with an ICE vehicle. But tell me more than cam belts or changing water pumps has you into an engine in 100,000 km these days?
Edited by Evolution13
@Evolution13 the thought behind the post is that just maybe, some of these problems would be prevented if the cars were sent for servicing at regular intervals. Surely cooling of the battery and motor is one of the critical aspects on a EV. There must be some evidence in the cooling system etc of issues like that in the video.
A recall is what is required. A very obvious manufacturing fault. Like with VW Group fuel rail bolts. These are not checked at dealership servicing. Safety critical but VW do not seem to think so, or do the DVSA. A warranty longer than 3 years is what a EQC owner needs, or and BEV owner keeping them out of the manufacturers warranty. But in other countries there might be court actions or the Lemon Law.
@Evolution13 I get it that it should be on a recall, but I was trying to point out that if people were to submit their cars earlier for servicing rather than, in some cases, penny-pinching, then maybe faults like that Mercedes with the £6,000 cost for a replacement electric motor might be avoided.
I say 'penny-pinching' because it seems that some regard EVs as offering much cheapness and then go about squeezing as much more cheapness of ownership as is humanly possible. On the other hand, you have the more mechanically sympathetic owners of cars who never attempt to be first away from the traffic lights or use excessive acceleration and put their cars (as is the case with lots of ICE owners) in for oil changes, etc., well before the makers' recommended schedules. They also tend to catch the early warning signs of other problems before they become a major source of aggravation.
Coming back to that EV fire blanket for moment, I just discovered this footage from StatcheD Training of a demo / test of a EV fire blanket done in the US which does indeed show the hazard I mentioned about removing them once used.
An interesting point he makes in the video is that the use of a fire blanket is actually meant for and is best used on adjacent vehicles, especially when at a charging hub, as the fire blanket would then greatly reduce the collateral damage to other vehicles from sideways jets of fire from a battery in thermal runaway.
That makes me wonder just how they do that, when by the time the FF arrive on scene, the adjacent cars will have already been subjected to those flames and also involved. Unless, of course, those standalone fire barriers shown in the video towards the end are already in place?
Has anyone ever seen any of these in use at hubs?
Edited by Graham Butcher
Tesla's articulated truck come to Europe soon.
1000 hp and quickish charging..........
It'll likely not be. Legal here or in a number of EU countries due to visibility issues (or lack of) as far as I can tell. It certainly wouldn't be allowed in London and I doubt many FORS operators will be interested.
Well, if it's anything like the Cybertruck, that will be a no, then. First, it is 8 years since it was first introduced and supposed to be the best thing since sliced bread. In that time, mainstream European truck manufacturers have theirs out, and many are being used in Europe. Secondly, unlike Tesla cars, which were the first to do BEVs, and hence have a strong following in most places of the world, they are very late to the HGV market and hence have very stiff competition on their hands if, and currently it is a big if, they will be able to meet the regulatory demands of the home market.
China is recalling almost 3,000,000 Teslas over the flush-hidden door handles and concerns about their safety in an emergency, such as after a crash. I wonder how many other manufacturers will be doing the same. This type of handle seems to be everywhere these days.
Nearly three million Teslas recalled in China over hidden door handles - BBC News
Tesla recalls nearly 3m vehicles in China over door handle safety risks | Tesla | The Guardian
Tesla Recalls 3 Million EVs in China Over Door Handle Safety
Tesla’s Door Handles Lead to Its Biggest Recall Yet | WIRED
Tesla and others begin record vehicle recall in China | Reuters
Drive magazine indicates that they are not alone, other Chinese cars also recalled for the same issue.
Tesla leads 4.3 million cars recalled for door handle safety fears
No they weren't. Musk's Tesla were about 100 years late to the party.
New regulations were coming in anyway that Vehicles had to have manual door handles.
Discussed on here previously.
I know the recall above is Tesla specific but… flush door handles aren’t EV specific, so I don’t see how this relates to “the truth about EVs”.
I also have to go back again to the fire blanket and point out you are moving the goalposts again, a long term tactic used by every conspiracy theorist for centuries -
“EVs are serious fire hazard”
“They don’t combust anymore frequently than ICE cars which are also a serious fire hazard”
“That’s different, EVs are worse when they do combust”
“That’s fair, but heres a product being developed we can use to potentially help counter the risk when they do combust”
“Ahh but that’s only been shown in ideal circumstances so that doesn’t count and there’s no procedure in place for in the real world”
“But it’s just a concept demonstration, of course it’s ideal, like any other concept demonstration”
“Still different because reasons, they claim they don’t need to be serviced”
Etc etc
Everything has issues that don’t come to light until available and in use en masse. Then issues get resolved. But neigh sayers will always just move the focus to another point.
@Evolution13 Yes, I'm aware of that, applicable to new models, as it states in the article you posted, and the start date is 1st Jan 2027.
However, the links I posted are recalls on already sold cars in use; they also mention software updates to lower the windows in the event of a crash automatically and stickers being applied, presumably to make the body-coloured flush door handles more visible to responders, which suggests that it is being claimed that they are not obvious enough to rescuers trying to open doors from the outside.
It is not clear whether this recall is an interim measure while they design a retrofit replacement mechanical door handle. The article you posted also says that "previously approved models have until January 1, 2029, to update the door designs.
^^^ Yes i read it. Last night in motoring news. It is not only going to be only EV,s being recalled by manufacturers'. Tesla are quicker off the mark doing 'Their Recall'.
My mistake; they were the first to produce 1 million of them in 2020. GM with their EV1 and Nissan with the Leaf were the first to put them on sale.
Rewriting history.!! Reva G-Wiz or Citroen C1. Nobody mentioned 1 million until the above post. @Graham Butcher
Recently Browsing 2
