mk1 htp coil pack failures ime new i have a problem the same coil pack fails i am replacing it with one from a large well known suppler any ideas
2004 Skoda fabia coil pack keeps failing ime replacing it with a budget one from a large well known suppler any ideas
  • Sponsor
Have you checked the spark plug(s)?
there not that old but i have spare set hanging around ile swap them tommorow
  • Sponsor
What is making you think they keep failing, fault codes? Have you tried swapping them around to see if fault follows coilpack?
Is it the 6-valve 54bhp or 12-valve 64? Which cylinder is giving the trouble?
same cylinder number 3 on the passenger side uk car
Just now, FRED_BAILEY said:
same cylinder number 3 on the passenger side uk car 6 valve
  • Sponsor
I would get a compression test if there's nothing obviously wrong with the spark plug on cylinder 3.
brothers car this may cost me a fortune its low mileage  though i know that dosnt mean much
  • Sponsor
You can buy a compression tester for about £15.
Edited by Wino
got one
2004 1.2 HTP 6V is definitely going to have burnt valves causing a misfire, stop buying new coil packs and check the compression now.
  • Sponsor
Fingers crossed that it doesn't tell you anything too sad.
Wishing you the best of luck in sorting this out, @FRED_BAILEY. :)
