Door mirrors when reversing
My left door mirror doesn't dip on reversing. I can manually do it by selecting L on the mirror control switch. It's set up to dip in the settings.
You need to leave the switch pointing to L - the mirror will return to its set position when you select a forward gear
Thankyou!
Just to add, it returns when you get to X mph (I forget what), but you do have to be moving forwards before it returns to its normal position.
You may also have to set the reverse-position as well before you can use it.
I think it's 15 km/h or 10 mph... 🤔
Thanks all😀
