Diagnostics
Hi all, where would I look on here for someone local to me who has diagnostics capability for a Fabia Mk 1 Petrol 1.4 16valve Please. Thanks
You'll need the VCDS owners map from this thread.
Hope this helps. :)
Thanks for that,I have messaged a couple. Thanks again
You could also tell us what it's doing, the 1.4 16V is so well known to some of us that simply telling us what the symptoms are may get you the answers you seek.
Edited by sepulchrave
Sure, no problem. the main issue is that the EPC lamp is on. I have put a new evap valve on and it has made no difference. It has also had a full service ,again its made no difference. The other problem is my fault, I removed the dash to check the wiring ,without removing the battery. I dont know if anyone can help, I would appreciate any help
  • Sponsor
Check that your brake lights all work first.
Then if they're all OK, check the brake servo vacuum hose at the joints with the non-return valve. Look and feel for splits all around the hard plastic section where it stretches over the hose barbs.
thanks will do
