Alloy Wheels
Hey Everyone,
I was just wondering if anyone knows what the best alloy width or offset would be to get them to sit flush with the wheel arch?
3 hours ago, OldManWitton said:
Hey Everyone,
The rim width and offset partly depends on the tyre size.
Narrower tyre tends to have less offset.
Wider tyre tends to have more offset.
Take a look at wheel-size.com to see what rim widths and offsets the Fabia MK2 uses as standard.
https://www.wheel-size.com/size/skoda/fabia/2010/
wheel-size.com does often make mistakes, but you should get the general idea.
Also, take a look at these 15" Audi A1 rims.
You can see rims with 6Jx15 ET29 and 6.5Jx15 ET34 specifications.
https://audi.7zap.com/en/rdw/audi+a1/a1/2014-708/6/601-601050/
185/55R15 fitted to 6Jx15 ET29 or 195/50R15 fitted to 6.5Jx15 ET34 might be a good starting point for that flush with the outside of the wheel arch look.
6Jx15 ET29 steel rims on mytyres
ALCAR 7415
https://www.mytyres.co.uk/rims/rim-selector?type=steel&vehicle_ids=46711651994440804
Edited by Carlston
Hey Everyone,
If they sit flush with the wheel arch they'll hit it under full compression.
