Octavia mk2 both rear windows & lots of error codes
Hi folks,
The rear windows in our 2011 Octavia mk2 haven't worked since we bought it a couple of years ago. I finally got around to scanning with ODBEleven and there a bunch of errors; see below. I think the previous owner had it looked at before and the summary description was it needed a part replacing - unfortunately, no more detail than that. I believe both windows failed together which leads me to suspect a more central issue (not a fuse though). I have errors on all the doors bar the passenger to do with central locking but they all lock and unlock fine - never had any intermittent issues either. I'm thinking it is related to the comfort (system) module. For a start, in the data log nothing is reported, not even any info and when I tried to read anything from it directly in OBDEleven it times out trying to connect. Do you think I'm on the right lines? If it is the CCM, how can I go about coding a replacement given I can't read the current coding? Any pointers greatly welcomed. Looks like I have a glow plug to replace as well 🤦‍♂️
OBDeleven data log
Date: 2022-01-21 19:52
    VIN: TMBHS21Z8B*******
    Car: Skoda Octavia
    Year: 2011
    Mileage: 157070 KM
01 Engine
    System description: R4 1,9l EDC  000SG
    Software number: 03G906021TB
    Software version: 2047
    Hardware number: 03G906021AN
    Coding: 0000071
    Trouble codes:
        P161B - Glow plug cylinder 2 Open circuit
            static
                Priority:  0
                Frequency counter:  2
                Driving cycle: 255
                Mileage: 101104 km
03 Brakes
    System description: MK70 M MASR
    Software number: 1K0907379AK
    Software version: 0105
    Hardware number: 1K0907379AK
    Coding: 0017665
    Trouble codes:
        No trouble codes found
04 Steering Angle Sensor
    Trouble codes:
08 Air Conditioning
    System description: Climatic
    Software number: 3T0820047M
    Software version: 0303
    Hardware number: 3T0820047M
    Hardware version: 150
    ODX name: EV_Climatic
    ODX version: A01005
    Long coding: 0000000002
    Trouble codes:
09 Central Electrics
    System description: BCM PQ35  B
    Software number: 1K0937084D
    Software version: 0615
    Hardware number: 1K0937084D
    Hardware version: 103
    Long coding: 48180AB8A05BB1C04008008011000024420000AE524181605C4540000040
    Subsystems:
        System description: Wischer 29091
        Software number: 1Z2955119D
        Software version: 0601
        Hardware version: 26
        Long coding: 00D7B7
        System description: Innenraumuebe
        Software number: 1Z0951171
        Software version: 5101
        Hardware version: 008
        System description: LIN BACKUP HO
        Software number: 1K8951605A
        Software version: 9004
        Hardware version: H11
    Trouble codes:
        02391 - Terminal 30 reference Open circuit
            static
                Priority:  4
                Frequency counter:  1
                Driving cycle: 76
                Mileage: 94885 km
        01134 - Alarm horn
            static
                Priority:  4
                Frequency counter: 23
                Driving cycle: 78
                Mileage: 111226 km
15 Airbag
    System description: Q4 AIRBAG VW8   020
    Software number: 1K0909605T
    Software version: 2300
    Hardware number: 1K0909605T
    Hardware version: 003
    Serial number: 0038PC1ZZ190
    Coding: 0020788
    Trouble codes:
        00532 - Supply voltage Lower limit not reached
            Intermittent
16 Steering Column
    System description: LENKS.MODUL
    Software number: 5K0953521BM
    Software version: 0136
    Hardware number: 5K0953569D
    Hardware version: 009
    Serial number: 20100930201269
    ODX name: EV_SMLSNGVOLWS
    ODX version: A01004
    Long coding: 108A040000
    Subsystems:
        System description: E221__MFL-URO
        Software number: 3T0959537
        Software version: 0012
        Hardware version: H07
        Long coding: 820000
    Trouble codes:
17 Dashboard
    System description: KOMBI
    Software number: 1Z0920943M
    Software version: 0406
    Hardware number: 1Z0920943M
    Hardware version: H04
    Serial number: 00000000000000
    ODX name: EV_Kombi_UDS_VDD_RM09
    ODX version: A04089
    Long coding: 410B00
    Trouble codes:
19 Gateway
    System description: J533  Gateway   H27
    Software number: 7N0907530
    Software version: 5603
    Hardware number: 1K0907951
    Hardware version: 000
    Serial number: 300910F2001563
    Long coding: E9807F0600060200002303
    Trouble codes:
        00470 - Combination comfort databus in single wire Open circuit
            Intermittent
                Priority:  3
                Frequency counter: 53
                Driving cycle: 114
                Mileage: 152360 km
        01044 - Control module incorrectly coded
            Intermittent
                Priority:  1
                Frequency counter:  4
                Driving cycle: 255
                Mileage: 146598 km
25 Immobilizer
    System description: IMMO
    Software number: 5K0953234
    Hardware number: 5K0953234
    ODX name: EV_Immo_UDS_VDD_RM09
    ODX version: A03008
    Long coding: 000000
    Trouble codes:
42 Driver Door
    System description: Tuer-SG         009
    Software number: 1T0959701T
    Software version: 2120
    Hardware number: 1T0959701T
    Coding: 0000756
    Trouble codes:
        00928 - Lock unit for central locking Driver side Implausible signal
            Intermittent
        00105 - Signal central locking SAVE/LOCK on driver side Implausible signal
            static
44 Steering Assistance
    System description: EPS_ZFLS Kl. 69
    Software number: 1K0909144J
    Software version: 3001
    Trouble codes:
46 Comfort System
    Trouble codes:
52 Passenger Door
    Software number: 1T0959702R
    Hardware number: 1T0959702R
    Coding: 0000756
    Trouble codes:
56 Radio
    System description: BOLERO
    Software number: 1Z0035156G
    Software version: 0029
    Hardware number: 1Z0035156G
    Hardware version: 014
    Serial number: SKZ4Z3K1123522
    Long coding: 000004000001
    Trouble codes:
62 Rear Left Door
    System description: Tuer-SG         007
    Software number: 5K0959703A
    Software version: 2101
    Hardware number: 5K0959703A
    Coding: 0000144
    Trouble codes:
        00934 - Left rear window lift motor Electrical error in circuit
            static
        00934 - Left rear window lift motor no or incorrect basic setting/adaptation
            static
72 Rear Right Door
    Software number: 5K0959704A
    Hardware number: 5K0959704A
    Coding: 0000144
    Trouble codes:
        00935 - Right rear window lift motor Electrical error in circuit
            static
        00935 - Right rear window lift motor no or incorrect basic setting/adaptation
            static
        00931 - Lock unit for central locking Right Rear Implausible signal
            Intermittent
        00108 - Signal Central Locking SAVE/LOCK right rear Implausible signal
            Intermittent
77 Telephone
    System description: Telefon
    Software number: 3C8035730A
    Software version: 0078
    Hardware number: 3C8035730A
    Hardware version: 007
    Serial number: 35909603051733
    ODX name: EV_UHVPremi
    ODX version: A01005
    Long coding: 020000000100010000000000
    Trouble codes:
        B104813 - Telephone microphone Open circuit
            Intermittent
                Priority: 4
                Malfunction frequency counter: 1
                Unlearning counter: 93
        B105311 - GSM antenna Short circuit to ground
            static
                Date: 2085-12-13 00:05:57
                Mileage: 94725 km
                Priority: 4
                Unlearning counter: 76
im no expert but alot of those error codes could all be down to bad earthing. theres a few earth connectors around the car, i would start there and clean them all up and make sure the connections are all solid. then start looking at the wiring looms especially where they pass through door pillars and connection blocks for breaks, grays or water damage.
Fractured cables in the drivers door bellows.
Checked rear door bellows, all looks ok in there. That wouldn't cause the CCM not to respond though, would it?
looking okay and being okay may not be the same. you really need to get a multimeter on it and continuity check them in case theres a split inside the insulation. you also really need to check the driver door one as thats got the most daily wear and also the most likely place to give an issue affecting many bits of the car.
The CCM not responding doesn't necessarily mean anything, it can be a limitation of the software.
Try a quick test to see if the motors are getting power: Put the key in the driver's door and turn it to unlock, the hold it there. The windows should all wind down, turn it to lock and hold it there to wind them back up.
I'm thinking wiring damage in one of the door shuts, or corrosion in the multiplug.
Tired the key in the door trick - what I've uncovered there is another problem as the key isn't operating the lock. Not going there, already got a door in pieces on my old Passat to fix a cracked solder joint in the lock mechanism. Holding the lock/unlock button on the key operates just the front door windows though.
I've got hold of vcds this evening. A full scan shows the same errors (not checked in detail yet) but it also shows the CCM as being installed. If you target the CCM directly, again, it times out. I find this super suspect, given the CCM is detected on the CAN bus yet can't communicate with it and fits with the original summary diagnosis when we got the car (admittedly, this is also swaying my suspicions). Feels like it'd be a poor design if the controller would become unresponsive if there were issues downstream.
Lack of daylight preventing any deeper investigation of wiring faults at the moment. Anyone know where I can get a wiring/component location diagram?
@Wino is a generally reliable source of diagrams?
  • Sponsor
Not familiar with Octy 2 systems but could try to have a look at some diagrams tomorrow and maybe come up with some suggestions.
All Skoda wiring diagrams are available to download as massive pdf files via erWin Skoda. Can be downloaded comfortably within an hour with lots else, which would cost you 7 euros plus tax.
I've explained on here many, many times how to get to these downloadable pdfs, e.g. here https://www.briskoda.net/forums/topic/491660-wiring-diagrams/?do=findComment&comment=5522236
Rear windows fixed! Thanks for the suggestions. It turned out that when the previous owner fitted a dash cam the fuses got messed around with and the rear window one got removed. I'd checked before but must have misread the numbering and wasn't expecting a fuse not to be present at all.
CCM still doesn't respond which is a bit odd but nevermind.
