Maps error
Hello. I'm new on this fórum and i neves help to solve a problem with my car gps. I tried to update my as card, but when i make de backup of Skoda sd card my computer broken and i miss the entre information on Skoda original sd card. Who do i solved this problem?
Thanks for tour help
There is no hidden information on the SD card so you need to format it correctly then add the appropriate maps.
The only check is the SD CID is correct, this cannot be changed nor wiped :)
Thanks for your answer. But i dont have de map 2015 and i dont know where i dois it. Because my sd card have just 14 GB of space
I've no idea which headunit or generation you have.
Assuming it's an Amundsen:
- If it's a MIB1, then I believe a 16GB card is fine for the latest maps: https://www.briskoda.net/forums/topic/481828-amundsen-mib1-map-update-2020-2021/
- If it's a MIB2, then the 'full' Europe ECE AS(A1) maps won't fit on a 16GB card without deleting some files but the other ECE packs will: https://www.briskoda.net/forums/topic/498473-amundsen-mib2-map-updates-202223/
At a guess, ECE 1 (Andorra, Belgium, Faroe Islands, France, Gibraltar, Iceland, Ireland, Ireland, Luxembourg, Monaco, Netherlands, Portugal, Spain, United Kingdom) should be OK for you :)
My system is thatIMG20220206201635.thumb.jpg.a80e7b0fa008b5f1090fed418140cc9b.jpg
Its an Amundsen MIB2
That's a MIB2 Amundsen.
I would suggest you use these maps:
# ECE 1 2022/23  6.6 GB
 VW portal:   https://vw-maps-cdn.lighthouselabs.eu/vw-maps/DiscoverMedia2_EU1_1810_V15.7z
 VW portal:   https://navigation-maps.volkswagen.com/vw-maps/DiscoverMedia2_EU1_1810_V15.7z
Files inside:    2021.05.12
Downloadable:    2021.11.21
Published:    2021.--.--
 Škoda portal:   - -
 Seat portal:   http://seatmapdownloads.akamaized.net/EU1/EU1_STD_1810.zip
Downloadable:    2021.10.19
And follow this guide:
Which will give this coverage:
Thank you. I will try that at evening and i tell you later if works
It works. I just have gps. Thank you so much
