2006 Fabia vRS Near Side Rear Door Carrier 6Y0839751AR
Hi
Need to get a near side rear door carrier for a 2006 Fabia vRS - part # 6Y0839751AR
Seem to be as rare as hens teeth
Any suggestions where to look?
I may have found one in Holland but would prefer a UK sourced one if possible.
I don't come up with the same part number. 6Y0839755 or 6Y0839756 seem better matches.
Just to be sure I need central locking and manual window operation
I guess thats what the suffix to the part number is?
30 minutes ago, Chester said:
Don't think that one is any good as it looks like manual locking, not central
The wiring loom to the lock has been cut, did you need the wiring loom as well then?
The vast majority of Fabias had rear windy windies with central locking, the VRS is exactly the same, it's just a Fabia.
Ah OK - so you're saying either one of those would fit?
I don't need the wiring loom
Don't think this  one would be any good
https://www.ebay.co.uk/itm/Skoda-Fabia-Mk1-Rear-Near-Side-Door-Window-Mechanism-Manual-Regulator-/133954069682?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=710-127635-2958-0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5336836713&toolid=10001&customid=38947X1001323X402dca82d1770dc9d220d8edb06291a3
The window winder looks to be in the wrong place - mine is in the stamped out circle next to the one on the above part. Maybe this one is for rear electric windows?
  • Sponsor
I think that's for electric rear window.
What happened to your original?
The plastic part that the window slots into has broken
  • Sponsor
Maybe this would be the way to go, rather than secondhand where the plastics will be old and possibly about to break?: SKODA FABIA WINDOW REGULATOR REPAIR KIT REAR LEFT N/S | eBay
New genuine via @vindaloo's first part number will be around £70 from a dealer, I believe.
New aftermarket of whole panel is probably another good solution if you can find one.
  • Sponsor
Correction: I think @vindaloo's numbers should end 655 and 656 rather than 755/756?
Perfect - thats the bit that has broken. Didn't know that you could buy just that bit.
There, you just have to ask the right question next time.
