HELP, Coolant leak after using the organic one!
An update, i did a flush, twice, respecting the cool down times between clycles...  and fill with destiled water and ag13 concentrated, small leak first days, no more leaks so far.
  • Replies 50
  • Views 7.7k
  • The amount of time ive been working on cars... I can assure you using the wrong coolant causes 2 things - jelly like substance or corrosion to the cylinder head if ally - not a quick process and happe
  • sepulchrave
    sepulchrave
    Not a chance.   That muppet mechanic knew the job wasn't done right so he's blaming the coolant.
  • Modern coolants work off a Silicate based OAT - Organic additive technology these additives carboxylates and triazole are a form of mild acid hence why leaving them on paint work is not the best of id
