Brake Pads and Brake Sensor Superb Combi 2.0 TDI manual
I have 117.000 km on my car (73000 miles) and I'm still running on the original TRW brake pads front and rear. There's still some thread left but I think I'm going to replace them soon but just to make sure, specially the rears, as I don't know if they have a wear sensor.
- Do you know if rear brake pads have a wear sensor?
- What TRW numbers should be used in a Superb Combi 2.0 TDI manual from 2017? Are those reference numbers OK?
TRW - GDB1956
TRW - GDB1957
Thanks in advanced,
TRW - GDB1956
TRW - GDB1957
Thanks in advanced,
Those are the correct TRW front and rear brake pads. The front 312mm brakes are a TRW system, whereas the rear 300mm brakes are an ATE system. You might find that the original rear pads are branded ATE. The rear brake pads don't have a wear sensor.
Front brake pads with wear indicator
TRW GDB1956
https://www.autodoc.co.uk/trw/7489103?search=TRW Brake pad set (GDB1956)
Rear brake pads without wear indicator
TRW GDB1957
https://www.autodoc.co.uk/trw/7489104?search=TRW Brake pad set (GDB1957)
Thank you very much!
