Engine/Exhaust Chugging noise.... HELP!
Hi guys!
I need some help with a strange noise my car started making yesterday.
It actually started to stall on me whilst driving slowly around a corner in third gear (which is usually absolutely fine), switching to second gear it was fine.
Similarly driving on the motorway is fine, it just sounds horrible and chuggy while idling....
Does anyone have any thoughts on what it can be before I take it to the garage after the bank holiday?
Cheers!
Just incase anyone is interested, the garage firstly replaced the coil pack, but that didn't solve the issue.
So they then replaced the pcv breather valve which has mainly solved the issue. Can't say it's perfect, but for a car with 200k miles on the clock she's doing well!
Thanks for replying back. Guess your car is petrol?  A small tip, always post your vehicle spec and particularly engine / transmission if a mechanical fault. You can put in your signature.  You are more likely to get replies and replies that are close to the mark!
Thanks for the advice!
Again just in case it's useful for anyone, the car is a Skoda octavia mk2 vrs, 2.0 ltr TFSI petrol engine.
