Skoda Fabia 1.4 mpi -> auq 1.8t
Hey guys!
I have some problem with my project..
I tested my Fabia with auq 1.8t, and everything seemed okay.
But i noticed, the turbo gauge says its boosting with 1.3 bar.
So i turn back to go home, but after i stop, the car stalls.
Started the car, and only 3 cylinder working out of three..
I have new bosch tfsi coils and ngk pfr7s(same to pfr7q i think) plugs.
The overboost problem was caused by a missing earth from the n75(maybe), but now i got a Camshaft Timing Adjustment -Short to Ground fault code..
And the car starts only for 2 sec.
Anybody can help me?
I'm really sad, because i can't use my car about half a year..
Is the 2 second start possibly an immobiliser issue. On stock cars they usually start and then cut-out after a second or 2. What boost are you expecting as 1.3 bar is only 19psi so does not sound excessive.
Some hungarian guys says the stock pressure is 0.7, so i dont know.
But its not an immo issue, because i turned off the immo
And not every time 2 sec, some times 3-4
Fuelling issue perhaps? Fuel pump, fuel pump relay etc etc. :)
Fuel pump working, replaced the pump and the same problem
But my biggest problem is what is the Camshaft Timing Adjustment fault code.. 😕
Cam position sensor probably, you should check the wiring.
Wiring okay i think.
The yellow/balck wire is the negative wire and the other(green maybe?) Is the + or no?
Black/Yellow is normally a supply wire not a ground/negative,  ground/signal grounds are normally Brown, Brown/white, Brown/yellow
Thanks man, camshaft fault code gone now
But now i replaced the crankshaft sensor. And now the car wont start.. its a brand new sensor. There is difference between the 1.8t arx, bam, auq crankshaft sensor.
I dont know why is not working..
