Rear springs...replace?
Just to update you all. Springs were fitted yesterday, car drives and pulls caravan fine, drove about 120 miles yesterday. In the end the bill was 312 euros. 63 plus vat for labour ( hour and half). Each spring was 98.80 plus vat. They fitted Febi Bilstein 46925 which is Specced as 1K0511115BH, as original. They are advertised on Autodoc France at under 30 euros Inc vat!!!!
Daylight robbery...
Onward and southward.
Fats
Normal French retail margin, they will have paid less than the Autodoc prix publique.
Enjoy the rest of your touring with peace of mind!
  • 3 years later...
Hi All
An option listed for Springs on AutoDoc is “Bad Road” as against normal/std or sports
Does anyone know what the difference is and are the other features in the suspension or car you fit “Bad Road” to any?
2022 superb 4x4 170 tdi estate
Already got B6 to fit
Bad Road springs are most likely springs for cars equipped with rough road package. They have a little higher riding height, I think it was 20 mm?
If you mount these springs on the rear you also have to mount them on the front side (and maybe also mount matching shock absorbers?)
How do I find the factory build for my car
Springs wise?
Springs wise?
You can open an account on "skoda parts com" and park your Skoda in the garage with its VIN number. This apparently lets you get the OEM part numbers of various parts free of charge.
"skoda parts com"
https://www.skoda-parts.com/online-store.html
Edited by Carlston
Thanks Carlson
  • 9 months later...
Hi, I looking for rear coil springs replacement for stronger ones. Now I’ve white, 3x orange and brown. I’ve mk2 estate. Any recommendations? When driving with 4 people on board car catching the speed bumps. When I going on my own without any load everything is fine, just rear is a bit softy. (I’ve replaced whole suspension front and back inc shock absorbers).
Rear springs for the Superb MK2 marked (1 White, 3 Orange, 1 Brown) has OEM part number 1K0511115DE and build code 0YE.
3C0511115AF is two up in the hierarchy compared to 1K0511115DE.
Sach 994 337 rear springs (matches 1K0511115DE)
Wire diameter 12.25mm
Length 362mm
https://www.autodoc.co.uk/car-parts/oem/1k0511115de?supplier%5B%5D=253&supplier%5B%5D=32&supplier%5B%5D=246
Sachs 994 364 rear springs (sold to replace 3C0511115AE, 3C0511115AF)
Wire diameter 12.75mm
Length 357mm
https://www.autodoc.co.uk/car-parts/oem/3c0511115af?supplier%5B%5D=253&supplier%5B%5D=32&supplier%5B%5D=246
Kilen 65059 rear springs (matches 3C0511115AF)
https://www.ebay.co.uk/itm/391130827593
Edited by Carlston
Hi All,
New here so apologies if I have missed something or am posting in the wrong place.
I have read the previous posts on this thread as I have a MK2 2015 Superb Estate with a saggy rear......
Ironically I am also moving to France next year so judging by the previous posts I should certainly sort this before moving!
To get through the recent MOT my car had the following replaced:
Nearside rear suspension arm (left)
Offside rear suspension arm (right)
Nearside front anti-roll bar drop link (left)
Offside front anti-roll bar drop link (right)
I have always had issues with the odd speed bump scrape, especially if a tyre or two has lost any pressure, but this summer holiday trip with luggage, dog and towbar mounted bike rack was too much for it. Rear was very low and towbar was regularly making contact with bumps etc.
Since those parts being fitted the problem seems to have reduced, which surprised me a little as i assumed I most likely needed new coils, uprated coils, or auxillary coils?
I'm keen to solve this problem as I am intending on keeping this car and running it into the ground, I also need to spend a small fortune getting the clutch and DMF replaced which is going to painfully expensive too!
Any tips on:
Which coils to fit/how i check compatibility.
Can this be a DIY job (what tools req'd?), or is it garage only?
Any help much appreciated!
Ross
If it's a front wheel drive Superb MK2 estate with standard ride height (ie. not lowered ride height or increased ride height), then fitting slightly stiffer rear springs such as two up in the hierarchy should solve the soft rear end problem when the car is loaded.
As mentioned in my previous post the upgraded rear springs have OEM part number 3C0511115AF.
Edited by Carlston
Thanks @Carlston . I have a Greenline model which I think may be lower than standard models for efficiency, perhaps adding to my problems?
I appear to have three yellow dots on my rear coils. not quite sure how to add an image to this, or if I don't have that functionality?
Apologies, looks like a possible faded white one on the left, then the three yellow.
The Greenline does have lowered ride height. According to the Kilen spring catalogue, the Superb MK2 1.6TDI estate Greenline has rear springs with OEM part number 1K0511115BT.
1K0511115BT has one blue paint mark, and three yellow paint marks. This is the only Superb MK2 lowered ride height rear spring that has three yellow paint marks.
1K0511115CA is one up in the hierarchy, 1K0511115DG is two up in the hierarchy. However, 1K0511115DG might be too stiff so 1K0511115CD might be a better option as it's softer but longer than 1K0511115DG.
If 1K0511115CD lowered ride height rear springs don't give you enough rear end lift, then the 1K0511115DE standard ride height rear springs might be a good option. Both these springs have the same 12.25mm wire diameter, so should be about the same stiffness, ie. provide the same level of comfort.
Even the 1K0511115CD lowered ride height rear springs should lift the rear end of the car up by at least 12mm (more if the original rear springs have started to sag with age) compared to what you have now, ie. the 1K0511115BT lowered ride height rear springs.
Sachs 994 454 lowered ride height rear springs (matches 1K0511115BT) (build code 0YD)
Length 330mm
Wire diameter 11.75mm
Saches 994 363 lowered ride height rear springs (matches 1K0511115CA) (build code 0YE)
Length 333mm
Wire diameter 12.00mm
Sachs 994 360 lowered ride height rear springs (matches 1K0511115DG) (build code 0YF)
Length 333mm
Wire diameter 12.5mm
1K0511115DH lowered ride height rear springs (build code 0YG)
Length unknown
Wire diameter unknown
Sachs 994 373 lowered ride height rear springs (matches 1K0511115CD) (build code 0YH)
Length 342mm
Sachs 994 361 lowered ride height rear springs (matches 1K0511115CE) (build code 0YJ)
Length 342mm
Sachs 994 559 lowered ride height rear springs (matches 1K0511115CF) (build code 0YK)
Length 345mm
Kilen 65074 lowered ride height rear springs (matches 1K0511115CD)
Length 342mm
https://www.ebay.co.uk/itm/318939090159
Kilen 65056 standard ride height rear springs (matches 1K0511115DE)
Length 362mm
https://www.ebay.co.uk/itm/336905897118
Edited by Carlston
Thank you very much @Carlston .
I think these could be the best bet:
Length 342mm
Would fitting these require new shock absorbers, or is the coil length similar enought to the original to not warrant a change?
The superb mk2 parts catalogue only lists two rear shock absorbers for the FWD lowered ride height cars. One is for the softer springs, and the the other is for the stiffer springs.
Aftermarket rear shock absorber brands will often sell you the same rear shock absorbers for lowered ride height, standard ride height, and increased ride height, ie. a one size fits all approach. So at least you have rear shock absorbers that are specific to lowered ride height and FWD...assuming they haven't already been replaced with aftermarket shock absorbers.
Bilstein B4 19-151083 rear shock absorbers are sold to replace ten different rear shock absorbers including both 3C0513049BD and 3C0513049BE lowered ride height rear shock absorbers, and a number of standard ride height rear shock absorbers.
Lowered ride height is also known as sports suspension.
Superb MK2 rear shock absorbers (1JC=Lowered ride height/Sports suspension) (1X0=Front Wheel Drive)
3C0513049BD
Rear shock absorber
for sports suspension
0YB,0YC,
0YD,0YE
3C0513049BE
Rear shock absorber
0YF,0YG,
0YH,0YJ,
0YK
Edited by Carlston
Here I look at the lowered ride height front springs and the standard ride height front springs for the Superb MK2 1.6TDI. These front springs will be the same on both the hatchback and the estate versions of this car. It's the rear springs that usually vary depending on whether the car is a hatchback or estate, with the estate usually having slightly stiffer rear springs than the hatchback version...all other things being equal.
Although 338mm-306mm=32mm, that's not the difference in the front unladen ride height because when you take into account the different wire diameter and number of coil turns the difference in the front unladen ride height is about 20mm.
This could be useful if you decide to fit standard ride height front and rear springs. Kilen came up with the OEM part numbers and Sachs has supplied the specifications of each spring.
Superb MK2 1.6TDI lowered ride height front springs 3C0411105P
Length 306mm
Wire diameter 13.00mm
Number of coil turns 5.25
Superb MK2 1.6TDI standard ride height front springs 3C0411105B
Length 338mm
Number of coil turns 5.75
Edited by Carlston
Thanks again for your help.
I've found a very good deal on two SACHS 994 337 standard-height rear springs (1K0511115DE) and two SACHS 311 346 rear shock absorbers (3C0513049CP), costing £140 altogether.
I'm leaning towards this setup now.
Do you know whether the GreenLine and standard-height rear suspension use the same upper and lower spring seats, bump stops and shock absorber mounts? Are there any other components I would need to change when converting the rear to standard height whilst retaining the lowered front suspension for the time being?
The upper and lower rear spring seats are the same for lowered ride height, standard ride height, and increased ride height.
Rear stop buffers
3C0511359B is the rear 118mm buffer for lowered ride height
3C0511359 is the rear 133mm buffer for standard ride height and increased ride height
LLLPARTS has a superb mk2 parts diagram, but their security system can make it difficult to enter. If so, then access the website using "https://www.lllparts.co.uk". Then you may have to press the refresh button. Then enter "https://www.lllparts.co.uk/catalogs". It should be plain sailing from there.
The lowered ride height front springs are about 10% to 15% stiffer than the standard ride height front springs, so it might be better to go up two in the hierarchy with the standard ride height rear springs to 3C0511115AF.
Sachs 994 364 matches 3C0511115AF. Bear in mind that some owners find the standard ride height rear springs on the Superb MK2 to be on the soft side, especially if a lot of weight is carried in the back.
Edited by Carlston
