Mib3 map update
New maps update available on SK Portal:
PS C:\Users\> curl -s -L https://updateportal.skoda-auto.com/en-GB/Updates/TMBAJ7NX5MY023717 | Select-String -Pattern "(http|ftp|https):\/\/([\w_-]+(?:(?:\.[\w_-]+)+))([\w.,@?^=%&:\/~+#-]*[\w@?^=%&\/~+#-])" | Select -first 2 -skip 1 | Select-String -Pattern 'OI' -SimpleMatch
        <div style="display:block; position:relative" class="map-download-btn" data-toggle="modal"
data-target="#DownloadEula" onclick="showEula(event,
'https://infotainment-cdn.skoda-auto.com/base/maps/OI_P119_EU_202425_Offline_Update.zip', 'OI_P119_EU_202425_Offline_Update',
'Map')" value="Download maps">
  • Replies 53
  • Views 31.9k
  • kodiaqsportline
    kodiaqsportline
    Although it's sometime since the post was made, returning to the original question might help someone.   It was a MIB3 system and the year according to the OP's profile was 2020 - just like
  • Hi I've just tried to download the latest map, following my earlier guidance, but I'm afraid, like you, I still get the USB ports in engineering mode greyed out. I don't know why it worked for th
  • See how that goes. I'd be interested to know whether anybody can find the drive in the engineering menu which you couldn't.
Hello @MartiniB,
First of all apologies for my late response but I've been in a short holiday last week.
During this break, I've also managed to update the Nav DB with the latest files from the Skoda portal:
Now the version displayed in System Information Menu is: 23.12
How does that compare with MartiniBs pinned file for 2024. VW one. You'd have to load it up.
https://www.briskoda.net/forums/topic/513799-mib3-map-updates-2024/
I guess if it updates it's newer. Not sure whether we are with the June 2024 release. You'd have to register with VW and check. I don't think MartiniB has posted those up yet if a newer one has arrived.
I'm waiting for a clever spark to publish how you derive the YY.MM in mib3 files. It's  buried in Hex so a simple scan of the files doesn't show the date code.
