Flashing LED lights
Hi
New here can anyone help?, I fitted h7 and h1 led headlight bulbs, I don't get any bulb out warnings on the dash, but what happens when I switch the ignition on they flash about 5 or six times, only happens when I switch the ignition on. Is there anything that can done?. Thanks.
That's the bulb check function of the control module operating to check the bulbs (if they were halogen) are OK and intact.  Either ignore it or get someone with vcds to turn the function off.
Thank you for the reply, yes I am aware that it is a bulb check function but my question was can it be turned off with vcds?, I have tried so called canbus eliminators that did not work as it was only a capacitor in a box, I haven't tried load resistors (yet) but the problem with them is they get very hot and I would not be able to fit them inside the headlight as they would melt the plastic, do you have vcds?, and do you know if it can be done?. Thank you.
I don't have Vcds and don't have an Octavia any more but did have the bulb check function turned off when I did so it should be possible.  I don't think load resistors will work as your not getting bulb out warnings so there may already be some within the Led module.
For info are the LEDs any good as I've heard bad reports on the light spreadand focus for them and only ever fitted HIDs to our old Octavia which were great.
Hi, The LEDs are excellent the beam pattern and focus are exactly the same as when the halogen bulbs was fitted that's on the H7s. The H1 bulbs I had to modify the bulb holder as the LED was horizontal and the beam pattern was awful, modified the bulb holder so the LED was vertical and they are spot on, the difference is amazing, I had HIDS before but these are ten times brighter, never been flashed by an oncoming vehicle. Yes the LEDs do have some sort of driver box on them, I might try load resistors if they don't work I have a set of H7s without the driver box on, and they did bring the bulb out warning on, and yes they did flash too so may try them with the load resistors if they do not work on the other ones.
