Key fob not working VRS
Afternoon peeps,,
I’ve just replaced the battery in the fob CR2016 is what was in it originally, but when I tried it it still didn’t work,, I had a search and it says press a button and within a minute open the door to sync fob,, this didn’t work 🤣, wasn’t even sure it that is the correct procedure to re-sync it 🤣,,
the buttons on the remote look a tad worn but they do click when pressed.
is there a way to sync the or is there something I’m missing like checking a fuse 🤣,,
thanks peeps
Does the red LED on the key flash when you press a button?
no mate what red light ?? Is it that dimple top right ?? 🤣
Yes.
AFAIK the fob uses a CR2032 coin cell.
Edited by MicMac
23 minutes ago, MicMac said:
Yes.
Ahhh so the lad I bought it from has put the wrong battery in as it had CR2016 not a CR2032. I’ll buy another battery and see if that helps
Any particular brand ?? Or will any do mate.
Put in a Panasonic CR2032 and the light still doesn’t flash mate,,, guessing that means the circuit board bit must be bad,,, is it possible to buy the board part and replace it with this faulty one or even a secondhand key and put my blade and chip in that
Ensure the cell is fitted correctly.
It's probably just a bad solder join of the cell tabs on the board.
Try wiggling the cell whilst pressing a button and watching for the red light.
No joy I’m afraid but I will still buy another just to rule out a dodgy/flat battery’
thanks for taking the time to help mate really appreciate it
No worries.
