How to get radio code ??
Morning peeps,;
I’ve just had a thought 🤣,,, my car has the bolero radio and I was scrolling through the settings and noticed it says activate Bluetooth audio ?? But my iPhone can’t find the radio ?? Is there a module needed as I can’t even add my phone for phone calls??
 This is when I thought does this radio require a code should battery fail ??
would I need to go to Skoda for this ??
Edited by Hardy1812
Have a look under the driver's seat to see if a BT module is there.
If the Bolero is OEM to the car then you won't need to re-enter the code as the car stores 'a few' such numbers.
Ahhh cheers mate,,
I’ll go and have a look for any kinda box thing under the drivers seat and get back too you
Normally no need to code the ICE manually, but you do need a stealership to get the code if you do need it.
Had a look and can’t see nothing under drivers seat 😢,,
