iV 93O5 Recall high voltage battery insulating mat
Hi all,
I’ve just had a letter from LEX with a recall for my iV.
It sounds pretty serious but then says no danger in “regular driving”. 🤔 what’s irregular driving? 😂
“In the event of a short circuit in the high-voltage system, the fuse blows and interrupts the current flow as intended but it could burst. As a result there is the possibility of a voltage flashover into the vehicle interior. This creates a fire hazard and possible risk of injury to the vehicle occupants”.
It reads like they will add a second protective mat during the recall works.
just wondered if anyone else has had this yet and if you’ve been able to get the work done?
I contacted the local high voltage service centre and I’m on a waiting list I believe.
It’s across the entire vag hybrid range. It is literally a foil mat that sits on top of the fuse and contractor area.
Just had the same letter through. No doubt there's going to be a long wait to book it in!
@Patent Did yours come to you from the Lease Company that got the RECALL or from Skoda / VW UK that send out to Registered Keepers or should from the Contact Information from the DVLA?
@roottoot via lex. Interestingly they advise the repair time is 6 hours!
I can imagine the appetite for a the dealer to have that taking up the ramp for 6 hours is slim to nil. I'm going wait and get it done with the next service.
It looks like in the main it will be 'Contracted out'.
Not that urgent a Safety Recall as far as the DfT / DVSA must be concerned after VW Group told them they would deal with it.
I guess they have enough product data to show that a HV system fuse blowing is a rare event in the first instance?
If it happened when you were driving I'm sure the bang would be enough to get you out of the car anyway!
Time will tell.
Like when DQ200's were in a Global Recall excluding Europe where it was not a Safety Issue because when you lost drive you could roll the the road side.
Australia is now on the 3rd recall due to all those that were missed at previous Service Campaigns and Recalls.
This is at least a full RECALL in Europe and a 'Safety matter'.
A bit slow in actions being taken but then you can trust VW, after all they are not Vauxhall, Mercedes, BMW or other European based manufacturers that drag things out.
Like with the 1.5 TSI kangerooing issue that had owners / drivers vehicles in dealerships for weeks while their cars awaited software updates.
Yeah I remember reading about the 1.5 issue. It always struck me as odd, surely they noticed the problem in testing?
There was no issue, and then VW Group were not ready for the WLTP  & RDE 2 and had to get Certification to be able to get the cars turned out so they were fine for the tests just not for on the road.  Tweak the software and if the car runs like crap then not all will complain.
Say never heard of that, then it is a characteristic, they all do that, (except those that do not.) but important is first deny any issue for months.
Just as has happened with The IT Software more recently. they turn out the vehicles and bring in the money and they might eventually see that the cars are fit for purpose.
That is the VW way.
This fundamental Design or Manufacturing / material failing will be resolved as cheaply as they can get away with in Europe and in other world regions where they can get a new one torn in court of by the authorities they will get a shift on.
Edited by roottoot
To be fair, having come from a Passat with MIB 2.5 to a superb with MIB3, I'd actively avoid another new VW/Skoda/Seat for that reason alone.
  • 5 weeks later...
So i've just received the same letter via Leaseplan namely, my vehicle is subject to recall 93O5
Speaking to a nice girl in the local Skoda garage in West Midlands, its not a job that can be done by any local dealership, it has to go to 1 of 2 (yep you read that right !), only 1 of 2 facilities in the UK, either Southgate (North London) or Cambridge !!!!!!!!!
WTF !!!!!!!!!!!!!!!!! 🤯🤯🤯
So my car has just been booked in for the next available slot.........January 2023 !!!!!!!!
:rofl:
What an absolute shambles of a company
Rather than train the local garages they do nothing and just sit customers in a massive queue and sitting on a potential risk to what could be life threatening by the sounds of it for anyone inside the car !!!!
To Mr Andrew Ganney (Skoda UK Aftersales).......i trust you don't drive your own Skoda "tat" ????
roottoot.....unfortunately you wont be able to unless you local dealership is either Southgate (North London) or Cambridge
I've been told that they are the only 2 garages who can do the 93O5 fix !
what a joke
Fantastic. They should be quite good at it by the time January rolls around!
…that’s if your car hasn’t burst into flames before then !
I think if it suffers a catastrophic HV fault whilst driving, the fire would be the least of my worries!
