Which swirl flap delete kit needed ??
Right P2015 code is now driving me potty 🤣,, I’m now thinking swirl flap delete ??
couple of questions if I may ask??
do I still need to leave the motor attached but not connected and do I need to keep it plugged in on the loom ??
does the kits come with plugs for to swirl flap holes or are they just left as a hole 🤣
is this the sort of kit I’d need,, I assume the red clips are just to block off where the metal rod goes through to link them together??
and the other plug goes in where the arm is ??
would anything need mapping out
thanks peeps
Search on YT and it's likely you'll get a walkthrough.
Had a butchers but can’t seem to find one 🤣
If you buy a kit from Darkside Developments they usually send you detailed instructions with it. Probably too late if you’ve already bought a kit elsewhere.
No not purchased one yet mate,, but I was looking and have saved Darkside Developments site,, gunna send them a message regarding correct one
thanks matey.
the one I’ve seen with them is only £24 plus delivery,, and looks like it’s just a 2 new gasket’s  and a bung for the arm end
Edited by Hardy1812
