Error codes
Good morning!
Octy Mk3, 11/2016, 125'000km, 2.0TDI CRMB 110kW not tuned, manual gearbox, without Keyless.
2 error codes are found with XTOOL VAG401 code reader:
17-Instruments / Malfunction
B104B31
Key, no signal. Passive/ abiogenesis
19-CAN Gateway / Malfunction
U120200
Bus defect CAN- diagnostics. Passive / abiogenesis
Those codes appears from time to time even after erasing. No other codes appear.
Car works fine, doors opens/closes, immobilizer works, key battery ok (and no warnings about key battery replacement).
Should I worry about those codes?
Google search for exact codes says almost nothing.
From what I've found, 1st code is concerned with problems with immobilizer/key synchronizing/etc.- but my works fine.
BR,
Indars
Edited by indars
error in kW
