Spak Plug
Hi -
Nedd help and advice regarding changing spark plugs on "Skoda Octavia -year 2011- Fuel-Petrol. Got ripped off last year for service on  my Car from Mechanic- Private - a friend I don't think.
I have bought tools to do it myself - Removed Oil Filer/Air Filter changed Oil no problems.
I changed 3 spark plugs no poblems but the second spark plug can not remove due to position on engine - any on out there who could help offer advice to complete this job.
Kind regards/Thank you
Tony/Dublin/Ireland
whats the issue with the no 2 plug?  Can't get the coil pack off?
Can not get plug spanner in position to remove- what do need to remove to gain access -thank again -Tony
I think we are going to need a photo.
What is actually in the way. Fuel line, breather line, wiring loom.
Could you use an articulated socket joint to allow you to turn away from the obstruction and at a different angle?
Hi the manifold blocks access to n02  n03 spark plug on engine -Thanks -Tony
Driving The Muppets GIF
Is this your engine model? What a faff. Other option is removing intake manifold.
Hi
Yes this is Skoda Otavia Engine Model OK- you are right this is a lot of trouble to change spark plugs -
TonySad Episode 15 GIF by The Simpsons
