So then….
…. does anyone have a clue how this could’ve happened and, more importantly, other than shelling-out a million quid (or an equally real sum I have no doubt) for a complete visor, can the mirror glass actually be replaced???
It’s a bloody nuisance that’s for sure!
Possibly from the visor flexing when flipped down/up?
Unlikely I’d think, as I always pull it down from the leading edge and push it gently back in the same way.
Anyone know if the glass is available as a part or is it the whole visor?
Looking over on the VWROC forum, a number of MK7 owners have had the same issue.
It can be dismantled - thanks to R Learner for the guide here.
So just need to get a bit of 3mm mirror glass cut to 130x70mm and should be quite a simple fix.
Edited by numskull
Speling
I'd really like to get the Passat extending visor. Should be an easy replacement. Just need to get the part number!
13 hours ago, boydeee said:
No one else has suggested it, so I'll bite....Did you look into it?! 😝
Lol, I was going to mention the same earlier - "the mirror saw something it didn't like, and cracked itself!!!" 😆
Edited by JR RS
Mine looks exactly the same. Only noticed  after some  opportunist  took advantage of an unlocked car door overnight. every cubby door open. I assumed he grabbed the visor looking for  cash or stuff. Will check the guide mentioned.
Mirror mirror on the wall who’s the numskullest one of all ?
Edited by Nick_H
Ok visor but that dunt rhyme geddit !
That’ll be me!
On 17/07/2022 at 08:11, numskull said:
That’ll be me!
im a very close 2nd !
