Weird Error Message (Only Leave vehicle in Position P)
52 minutes ago, Conalk45 said:
the service dept were to call me back… they didn’t call this evening.
Don't hold your breath. ;)
  • Replies 59
  • Views 25k
  • Chiselwizard
    Chiselwizard
    Had it fixed today at Hawco. TBH I'm not unhappy with the outcome. I was expecting a quote of ~ £1400 going by posts on another thread, as the usual VAG solution appears to be replacing the entire sel
  • I have attached a TPI to read, mainly for anyone following the thread in future.   Current repair kit is 3Q0 713 128, with the caveat that this might change in future at any point, as well a
  • I have asked if a mod could maybe change the title as the OP can not.  That will depend on if they are OK with that.
A bit of double-side sticky foam tape might do a better job, or blue tac which can be incredibly strong if left to settle for a few months but you still able to release the item later if required blue tac holds at least three items on to my car.  Held some hi-fi speakers to some very heavy ballasted speaker stands too.
  • 3 months later...
On 15/08/2022 at 21:52, Conalk45 said:
Quick update. The fault was repaired today they did not replace the entire selector. They used the switch repair kit - invoice read £125 for parts.
bad news… they broke a clip completing the repair 🙈😡
I watched a you- tube video recently where super glue and cigarette ash were used to form a replacement hinge or latch.
I just posted on another thread.  Same problem with Error Workshop etc.  No fault could be found so they cannot fixed under my extended warranty.  Can anyone tell me if this will became a major problem if I do nothing.  They have told me to come back when it happens again, leaving the ignition switched on so they can see the code.  They also told me they have other customers with the same problem and not to believe all I read on forums!!!
Please note - I am not a mechanic or expert in anything.
Yes it is quite correct not to believe all you read on forums but unfortunately it's very true not to always believe all that you are told by the motor trade.
It's perfectly possible to have faults without fault codes, I can understand that a garage will want to confirm what the fault actually is but they should also take into account any information you give them and it appears to be a known problem to them if other customers have reported the same message to them.
Have a look at this thread particularly the following posts on this thread.-
https://www.briskoda.net/forums/topic/505730-weird-error-message-only-leave-vehicle-in-position-p/?do=findComment&comment=5683796
https://www.briskoda.net/forums/topic/505730-weird-error-message-only-leave-vehicle-in-position-p/?do=findComment&comment=5685526
https://www.briskoda.net/forums/topic/505730-weird-error-message-only-leave-vehicle-in-position-p/?do=findComment&comment=5678753
HTH
Edited by nta16
changed to unembedded link addresses
58 minutes ago, freeb1rd said:
 No fault could be found so they cannot fixed under my extended warranty......and not to believe all I read on forums!!!
Mrs Gaz's Polo was fixed under warranty (26/07/2018).  This is a very well known and documented issue.  Useful other reading here:
In particular the post by Atenza, 15 May 2020 (page 13) 'Compliance Recall 37M2'. Part no. 5Q0-713-128-A  and TPI 2056031/6 may also be relevant (possibly superseded).
Gaz
2060686.3 - Fault Workshop! Leave vehicle only in position P.pdf
Edited by Gaz
Added a PDF
40 minutes ago, Gaz said:
In particular the post by Atenza, 15 May 2020 (page 13) 'Compliance Recall 37M2'. Part no. 5Q0-713-128-A  and TPI 2056031/6 may also be relevant.
Below, direct link to post* and its pdf.
ETA: click on the top part of link below, with the circled A and 15 May, 2020 or - https://www.briskoda.net/forums/topic/426096-error-service-leave-vehicle-only-when-selector-in-position-p/?do=findComment&comment=5399919
RCRIT-19V615-0044 (1).pdf
HTH
Edited by nta16
ETA:
  • 4 months later...
Bump.
  • 6 months later...
Bump again.
