"moan" when braking, especially in the wet and shaking under braking
As title: when I press the brakes after driving some time in the rain, there's a distinct "moan" first time out. They then proceed to wobble nicely. They work well enough. It's sporadic.
Yesterday drove home from the airport, where the car's been outside for 6 days, and the judder is definitely there from 60km/h / 40mph.
I figure a good first start is to do multiple stops from 100km/h to 25 or so and scrub them clean. That should indicate whether the discs are warped or it's just crud (I do tend to do 400km at a time and don't really use the brakes much - not much traffic and few turns will do this for you). But I don't understand the moan.
Any thoughts?
 . Bret
Crud.  Surface rust / corrosion.   Discs or pads or both.
Look at / inspect the brakes.
Servicing pre or post winter is a good idea, strip, clean  and grease.
and brake fluid change recommendation is at 3 years & then each 2.
