skoda superb 2016 columbus firmware
Hi people, , i m new here, sorry for my english (germany).. Noticed a few "drop out" of my columbus, version check "MHI2_ER_SKG11_P2104_1" MU 0318....have found "new one" MHI2_ER_SKG_K3343_MU1433...This version train supporting MHI2_ER_SKG11_P2104*! Can I install it? Or make something wrong? Please help!
Very Thank you!
SupportedTrains = "MHI2_ER_SKG11_P2104*,MHI2_ER_SKG11_S2104*,MHI2_ER_SKG11_K2129*,MHI2_ER_SKG11_S2129*,MHI2_ER_SKG11_P3260*,MHI2_ER_SKG11_P3304*,MHI2_ER_SKG11_P3325*,MHI2_ER_SKG11_K3330*,MHI2_ER_SKG11_K3333*,MHI2_ER_SKG11_K3343*"
Yes you are correct, the first entry in SupportedTrains list your currently installed.
So you should be able to flash with no problem.
Hi Varoom, tx too much for your help..i thought its can be problem because origin MU is 0318 and new one is 1433. i think, big jump :O)..but if you mind i can try it without risk...ill make it...
just one question...my superb is L&K , whe powering ON is L&K logo branded on display...its remain after update or gone?
Someone had same jump the other day, fingers crossed your file is intact (they should have checksums.
Yes sometimes VAG do make very large jump in numbers that seem extreme!
I am not sure as I have never flashed this myself, in theory it should take care of itself... usually no logo is changed.
I would need to check, but 99% certain I have old firmware here, and you could force downgrade, but highly doubt you would need this.
Just make sure to have stable power, so a battery support unit (official way)
But you can also start engine to provide power, just be sure to not start engine mid-update!
Ok Varoom, tx once again...Im downloading FW, later making a report! 😱
Tx tx tx!
Tx tx tx!
If your download link is slow, let me know... I have faster server 👌
Its about 70% , yeahm its slow, but its fast over now...if anything wrong happend, ill let you know!!!
Hello Varooom, ITS WORKS!! No error, no trouble, 20 min, everything OK! Tx tx tx!👌👍
Greetings from Germany!
  • 1 year later...
On 6/8/2022 at 17:42, didika said:
Hola Varoom, muchas gracias por tu ayuda... Pensé que puede ser un problema porque el origen MU es 0318 y el nuevo es 1433. Creo que es un gran salto: O). Pero si te importa, puedo intentarlo sin riesgo. .Yo lo haré...
Excuse me, what improvements does version 1433 bring?
U can read about that here.
