Looking for a felicia anti roll bar
Hi there, I am looking to put a 22mm anti roll bar from a pickup on my felicia. Does anybody know where i can get one from? I have tried local scrapers but there isn't any about.
Thanks👍
IIRC, 22mm is exclusive to Fun and it'll be hard to find. All other models had 20mm. It can be found on all 1.6/1.9 Felicias or 1.3 with ABS.
Cheers mate that's good to know.
I also thought that the caddys had the 22mms roll bar aswell
The price is very high for an estate item like this:
https://www.b-parts.com/auto-parts/engine-transmission/anti-roll-bar-skoda-felicia-i-6u1-1994-1995-1996-1997-1998-4017857
Back in the good old days Eibach sell this for Fellica (i have bought it, i have the 1.3 No ABS-Airbag edition) but now isn't on their catalogue any more.
That is a bit much 😅 hopefully I can find one that someone is breaking. I wish I could bring one back as hand luggage as I'm czech atm and there is a felicia or favorit on every street and many in the scrapyards.
Do you remember the difference before and after? How did it feel?
Before as we say here was ''like a boat'' ,is like the moving of a boat from left to right when is anchored in the sea which is not calm.
I installed the strut brace and after a while the anti-roll bar next, the car had already new lowered springs and new shock absorbers (Koni) so the whole ''package'' was far more ''tight'' and very useful in sport driving style in road mountains than the Stock.
I also added an ARB on my Felicia (with otherwise stock suspension) - the handling improved, especially with R14 wheels, the car felt stiffer and rolled less - but it wasn't too stiff, like more modern cars tent to be.
I later added a rear ARB to keep things balanced (my estate didn't have it from the factory)
That might be possible, since caddy had a 1.6 engine, which I've never seen in the Pickup - with exception of the Fun. I didn't find any official info about which variant was used on which model...
Thanks for your explanatory post. :thumbup:
Does this setup impose more lateral stress on the tires?
Better handling means a safer ride too. Good upgrade.
less actually
In all honestly i do not fancy anti roll bars on the felly, its just a light car and it does not need any IMHO only some more static camber...
In the past i had the idea for a rear strut brace, there was a guy here in GR which could make custom for models which you couldn't find as after market.
My main problem was that this rear strut brace was dividing my trunk space, i could load suitcases etc so i abandon the idea.
Below is an example from other brand, Renault but is very similar.
omp-rear-strut-brace-for-renault-clio-ii
Favorit was a light car, Felicia is some 100-200kg heavier.. My estate was like a boat, ARB was definitely positive. I agree, that modern cars with to stiff ARB can be quite nervous, but that's not the case of the Felly.
You are onto something with the cmaber - Felly has pretty low caster angle, so many people racing them are looking for various methods to increase it
Forman is heavier too. So what do you think about ARB + Strut Brace for a Forman?
Unfortunately, Forman doesn't have mountings for ARBs. You'd need to fit front axle subframe (which has different mounting points) and arms and rear axle from Felicia.
A strut "brace" is a method of locking in any pre-existing chassis twist. Avoid.
With Camber screws help?
Well caster is conservative and camber.
Adjusting the rear lower wishbone mount will give you one to the detriment of the other.
Generally speaking caster provides in corner camber gain and feedback so yes i think that is the more important to adjust angle
my alignment settings, I would like to change the front caster and camber (left wheel) and rear toe.... sadly i cannot😰
Edited by Thefeliciahacker
Could you explain please?
Correct me if I'm wrong but some Felicias have it from factory. Right?
How old is a Felicia, or your Forman?
That's how long it's had to develop a twist away from the factory specification. Now fit a chassis brace and instead of increasing chassis stiffness you lock in that twist.
Loud and clear sir. I like the way you think. That's wise.
That is not the case if you had a twisted chassis you would know about it.
No chassis is going to be subjected to permanent deformation in their proper use cases.
But yes felly chassis do not have great torsional rigidity and braces will help with that.
No locking pre-existing twist, not even close, if you havent been involved in an accident ofc.
Back in business. :)
Ladies and gentlemen, we have two conflicting opinions.
Bracing and old Forman/Felly. Do it or not?
Let's sauce it up a little bit. :D
All chassis twists, flex, etc. are pre-calculated by engineers before the cars' production right? There are expected places of stress on chassis. I think those places are strengthened too. So if you install a strut brace, will it impose a dramatic change to where the chassis flexes?
