Dreaded looping
It's C14+ and the original firmware as shipped according to the label was 6270
Hardware H23
Edited by Rumbeard
  • Replies 56
  • Views 11.8k
  • Hi mate...his ebay user name is rcd310...guy called Eric.   Carl
  • There is very big chance that just SW loading will solve your problem. You need SW 6276.
  • It doesn't matter, in RNS510 series you can SWDL (SoftWare DownLoad) mode by pressing 3 buttons and loading CD-R with SW burned.
Hardware H23
Well I do have this available then if you wish to try it.
S00.1000.07.99
#Integrationphase: Delivery cw45/13 C14-samples
#VwSwPartNumber:1T0035680T/3T0035680S/7F0035680D
#/7E0035680D/1T0035680R/1T0035680S/3T0035680Q/3T0035680R/1T0035686G/1T0035686E/1T0035686F/7F0035686A/7E0035686A/3T0035686K/3T0035686H/3T0035686J/7N5035686A/2H0035680A
#VwSwIndex:6276/6276/6276/6276/6276
#AppsBuild:C_EU_33.276_t1 C14
@Carl248do you have a link to the seller on Ebay as i am looking to upgrade my Swing radio to a Bolero or better.
Carl
S00.1000.07.99
Thanks worked better than expected.  Original HD OK and boot splash split fixed too.  I found a local guy who said I could get a VCDS backup cam re-enabled as the SWL disabled it.
  • 2 months later...
Hello.... I am new to briskoda and have only just seen this stream. I have a similar problem with a slight variation! Over the last few months the unit seems to have degraded. Sometimes slow to start, then maps stopped working and finally a black screen with a message swl initialisation in progress which then loops for ever and nothing else works. I was told that the hard drive was faulty so got it replaced. Tried the reset by using the 3keys and got message to insert cd which I tried but couldn't as dvd drive now locked!! It has now been suggested that the mother board is faulty but before I scrap the unit does anyone have any other suggestions? My unit is ...686N with dab etc...
  • 1 year later...
S00.1000.07.99
Hi, taking a chance that someone will read this thread from a while ago.
Mrs’s Rapid has a Columbus fitted and the looping error has arrived and “so horrendous driving without sound etc.”
the radio is a 3T0035686H, HW26, SW 6270, Maps 8477.
if anyone has or has a link to the firmware to make an attempt at solving this issue, it would be very much appreciated.
Here's hoping.
