Mk1 estate vrs window regulator
I’ve been a long time lurker and I finally picked up a mk1 vRS estate back in July. There’s a few small things wrong with it that I’d like to do soonish, two of which I’ve found parts for using this forum.
The third thing is the window regulator has gone on the rear left door. This has meant I’m using tape to stop the window dropping into the door. I’ve looked through the forums and I can’t find the product code for the window regulator. I had a VW Golf mk4 before so I know they go all the time so I’m sure there’s a post on them somewhere!
If anyone could help me out with the regulator code as I’ve seen two types online and short of me taking the door apart I’m not sure which one I need!
Thanks!
p.s if this is in the wrong part of the forum don’t hesitate to move it!
  • Administrators
Thanks!
This should do.
https://www.ebay.co.uk/itm/141898800777
I use the same company for their locking modules. Obviously, double check the listing to make sure it is correct for the door you want. You will need to swap the motor over to this unit, if it still works.
1 hour ago, DeanVRS20VT said:
This should do.
Excellent I’ve ordered that 😊
