Wheel nut cover tool
Spoiler
Can anyone send a pic of their removal tool and location for the plastic wheel nut covers
VRS 2.0 TSI Octavia Estate
Can't find mine . New car.
Looks like plastic tweezers (similar shape to sugar tongs) about 4 inch (100mm long).
Should be in the polystyrene in wheel well (along with locking wheel nut)
Here it is the set - plastic wheel nuts covers and the removal tool:
Nothing like that tbh
Most of the time they are stored end up, so all you see is the dome end, which is hard to spot against the black polystyrene.
17 hours ago, Tellster said:
  Reveal hidden contents
I could not find my tool so I phoned the dealer who said it is there in with the jack etc. in the polystyrene block .
Sure enough it was there just difficult to see. I bought a couple more from E-Bay.
DO NOT let tyre fitters have them, they always "Forget" to give them back.
Edited by gumdrop
Most of them don’t care about this tool. They just use a flat screw driver as a lever and make awful scratches on the screw wells
Turns out this is it
Could only see the right angle bit sitting in the polystyrene!
2022 VRS
2022 VRS
That’s not for removing the plastic wheel nut covers, it is for removing plastic wheel trims on lesser models, and sometimes to remove trim to access towing eye fitting.
tried a few months ago to get a set nut covers for my vrs but could not find them anywhere.any help please.
Plenty dealer shops on eBay and Amazon also available from your local dealer.
https://www.google.co.uk/search?q=skoda+plastic+wheel+nut+covers&client=safari&hl=en-gb&ei=U8haY_-8LYuZgQaK1InwDQ&start=10&sa=N&ved=2ahUKEwi_sv_Z_4D7AhWLTMAKHQpqAt4Q8NMDegQIBxAO&biw=1121&bih=1438&dpr=2
Edited by Kenny R
@Joss1733
Did your car come minus them because someone never fitted them at the PDI?
Fleabay ?  -  probably not OEM
I just got a set off fleabay that came in the original OEM labelled bag.
