Steering wheel crooked after front springs replaced
My Estate used to go a bit left on a straight road then a few weeks ago I treated it to a set of Rainsport 5 tyres and afterwards it tended to pull right slightly instead. I swopped the front tyres over after 100 miles and bingo, it drives straight. No idea why but I’m not complaining!!
  • Replies 51
  • Views 10.3k
  • You need to take it back, point out the failings and tell them it doesn't drive straight and to sort it out or you'll get an independent inspection and complain to trading standards.
  • I'm sure you're right. What shocking workmanship. ☹️
  • Seeing as the strut looks newer than the other side, it looks as though it's been replaced at some point? I think maybe that particular brand of strut just has less length at the bottom by design, mak
As has been said, get a computerised four wheel alignment done. This will give you a report on the entire front end geometry. If they've loosened the wishbone mountings that would put all the alignment out.
