Lifting a Yeti ... but by how much ?
Hi All , you've probably heard this a thousand times so please bear with me , I want to "lift" my stock 1.2 Yeti ( non 4x4 ) and seen plenty of lift kits ( Darkside etc ) starting about 20mm ... is this the maximum lift you can sensibly go before having CV drive shaft, camber issues etc .
Am looking to firm up the suspension too , not much just a little .... odviously cries of "HELPpppp" comes next 😂 .... I will be replacing the alloys with 16" steels and taller 50/50 split tyres .
Its going to be used mostly as a van / mini-camper etc ... so any other ideas covered please feel free to post .
Thanks in advance
Greg
ps selling mine and buying an outdoor 4x4 is not an option , as needing to stay petrol 😟
Check out spaccer.com for a strut top "liftkit" thing, I think they build them based on your VIN and are avaialable in 12/24/36/48mm height.
Thanks Joey , have a kit coming from Darkside , now just trying to work out tyre / wheel sizes . 😀
I lifted mine with the Eibach springs (Tiguan). Excellent results with 30mm lift and improved handling on road and off-road. I’m going for another 30mm soon with the spacers/levelling kit.
A Yeti with a 60mm lift? That I want to see! :)
 In the new year for sure!
I’ve done the maths and another 30mm lift will take the body just over the wheel centres. With minimal work on the wheel arches, I reckon I’ll be able to run 245/70 tyres on my 17s 👍🏽. I’ll push the width with wheel spacers.
im currently running Cooper ATTs 225/55 which are great.
Can't you use lower offset wheels instead of spacers?
Of course I can - huge price difference in a set of wheels vs spacers. But yeah, that’s a long term plan. 16s with fatter tyres eventually.
  • 6 months later...
Test 265/65 17 on the rear. Looks like my plan is going to work with minimal cutting or mods.
IMG_5412.thumb.jpeg.dc77e2df496630a2b6905b5f3ed4e1be.jpegIMG_5415.thumb.jpeg.e5d2b9b6f136708c9437705b352aef7e.jpegIMG_5413.thumb.jpeg.40025c9ec9a844ea81b3f45076c7dc52.jpeg
IMG_5414.thumb.jpeg.5ece6fd1d3c46b4443a961e7a8eeaef8.jpegIMG_5416.thumb.jpeg.ec00e7ab92f1cfe2289af2cdd2acca67.jpeg
Just think how much better your on road handling will be with 60mm! 🙄
A couple of bags of cement in the roof box will make it handle like a Formula 1 car!
Your rear bump stops are deteriorated and turning to dust but they would not do any good now as the vehicle will become coilbound before they could have any affect, a serious safety issue and should be addressed, you may be able to fit new ones together with 60mm cut down sections of the old ones.
It takes me back to fitting Jack-Up bars to the rear spring hangers of my MK2 Tincorner and then finding that both rear shock absorbers had sheared off at the top with the suspension on full rebound when I was trying to emulate the Dukes of Hazzard, - YEEHAAAH!
Edited by J.R.
The dampers have 40mm extenders and I have new bump stops and sleeves to go on. I won’t be jumping the car, just seeking footprint and clearance for sand driving.
Above was before the lifting spacers. This is about the maximum driving I do.
In the photo of the tyre mocked up in the wheelarch it is deplaced to the rear significantly , how are you going to go about increasing the wheelbase?
it’s just a mock up at this stage. I’ll mount the tyre on a rim and take a proper look. From the test it looks like I’ll need to cut out the forward wheel liner/inner wall.  More pics to follow. I might start a separate thread/post. Seems I’m hijacking this one
I think you might be OK, I was looking at mine today as the ride height looks quite similar to your 60mm lift despite it being standard "Offroad" trim suspension (it was slightly lower), my wheel was centred in the arch & then it dawned on me that you took the photo with the vehicle jacked up, the trailing arm will moving through its arc will have moved the hub forwards.
  • 3 months later...
Hi! how much did that lift impact the fuel economy, was it noticeable significant?  when 30mm or when 60mm?
Maybe with it lifted you might drive a bit slower so no efficiency loss.
Tyres might make a difference though.
  • 9 months later...
Looks fab.
Do you (or the collective wisdom) know how Tiguan and Yeti springs from Eibach compare with each other and the OE versions of each in terms of ride height?
I ask because I have L66 and 0YJ PR-codes for my Yeti, and in an attempt to improve ride comfort further, I want to pair Eibach springs with Bilstien B4 dampers but with a non-reduced ride height. Eibachs for a Yeti seem only to come in a reduced ride height. (I've already gone to 16" wheels/tyres)
Are your Eibach springs standard ride height (for a Tig) and would they on their own result in part of your ride height increase? Or are they reduced ride height (again for a Tig) that merely result in a Yeti being able to run standard ride height on Eibach springs, with the extra ride height coming form a separate lift kit?
TIA.
10 hours ago, tintinandcharlie said:
...I've already gone to 16" wheels/tyres...
The Yeti uses a 7J rim width for its 215/60R16 tyre size. This is relatively wide for this tyre size. For example, the Superb MK3 uses a 6.5J rim width for this tyre size and the Karoq uses an even narrower 6J rim width for this tyre size.
Using a 6J rim width instead of a 7J rim width for the 215/60R16 tyre size might have a similar effect on ride comfort to using 4psi lower air pressure. This could be the difference between a ride that's on the hard side and a ride that's acceptably compliant.
Another advantage of 6J rims compared to 7J rims is a potential large weight saving. The below chart shows that the 6J rim weighs 1.75kg less than the 7J rim, ie. a weight saving of 7kg for all four rims...or 8.75kg if you include a spare.
Weight of steel rims
Alcar 6665 6Jx16 ET43 5/112 57.1 steel rim 7.60kg
https://www.mytyres.co.uk/rims/details?vehicleId=1284041564754023536&rimCode=ALCAR6665
Alcar 9257 7Jx16 ET45 5/112 57.1 steel rim 9.35kg
https://www.mytyres.co.uk/rims/details?vehicleId=182363349315490928&rimCode=ALCAR9257
On "skoda eshop cz" the five 16" alloy rims shown for the Karoq are listed at between 9.5kg and 10kg each...so quite a bit heavier than the equivalent steel rims.
6Jx16 ET43 5/112 57.1 alloy rims (from Karoq)
https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?sort=priceAsc&q=%3AscoreDesc%3AcarType%3AKaroq%2B%282017%2B%29%3ArimDiameter%3A16%22#
The below alloy rim is the same specification as the Karoq rim, but comes from the VW T-Roc.
6Jx16 ET43 5/112 57.1 alloy rim 2GA601025Q 8Z8 (from VW T-Roc)
16 Inch VW T-Roc A11 2GA601025Q Corvara Kba 50515 Alloy Wheel Rim - Picture 1 of 1
Edited by Carlston
Thanks for the info. I'll start looking at 6J and 6.5J rims.
Do you know if either of those sizes have been approved for use with the Yeti? If so, are they suitably 'standard' for fitment to a 170?
Thanks.
TnC
The approved tyre and rim combinations are listed in the car's CoC (Certificate of conformity).
215/60R16 fitted to either 6Jx16 ET43 or 6.5Jx16 ET41 (or even 6.5Jx16 ET46 from the Octavia MK3) are non-standard on the Yeti, so won't be listed in the CoC.
Changing the 7J rim to a 6J rim is going to give twice the improvement in ride comfort compared to changing the 7J rim to a 6.5J rim.
Edited by Carlston
Can you tell us what springs you used, were they standard Tiguan or the lifted ones
Eibach are slow to respond.
Much appreciated
But why - just why? It makes a great car look ridiculous - something out of Dukes of Hazard.
Dear oh dear.
Recently Browsing 1
