Hello!
Morning!
Just a quick hello!
I bought the Fabia just before I really understood what was going on in America with the VW emissions scandal!
I've had a bit of a love hate relationship with it, however want to try and see if I can nurse it to 300K miles.  All my previous cars have made it to 200-220k, and were still going when I moved them on, and have accepted that will mean spending a bit of cash to make sure it gets there.  However when I look around me and see a lot of faux comments about the environment and then look at friends who are paying £400/month for the privilege of driving a newer car, I've figured my best option in terms of environment and money is to stick with this one for as long as I can accepting I will need the odd major repair/replacement.  And who knows I might even make a mod!
So to try and hit this 300K I've decided I want to try and be more hands on.  I'm starting at the lowest point possible!  I am no mechanic or engineer so changing the battery last week made me feel like an F1 mechanic!  Changed a headlight bulb (who knew it was so tricky for folks with big hands?); changed the air filter; and am about to change the fuel filter before finishing with the finale...the oil and oil filter!
I have in the past had a look on this forum, and the knowledge and expertise is brilliant so thought if I'm going to achieve the 300K aim, then being part of this site could be a huge help, so I am likely to ask a lot of stupid questions (although I promise to try and search for them first!).
The biggest issue I've had with the car has been its EGR valve.  I'm on 163K, and I am on my third EGR valve so think I need to seriously consider having it removed as its really expensive.
I've also bought a Ross-Tech HEX V2 scanner which I am currently trying to learn.
Anyway that's my hello!
Cheers
D
Agreed. Also agreed about just how restricted the space in modern engine bays is.
As for EGR, chat to some local to you taxi drivers about "who knows" stuff like EGRectomies.
Hello daes :hi:
Good on you for setting a 300k target, and a great car to be doing it in 👍
Gaz
