White stuff in engine bay
Ttr
Adblue injector or hose cracked - personally I’d replace both as they are fairly common.
remember the system should be purged once replaced else you may get a nox efficiency code appear after a few 100 miles
I've just found the exact same buildup in ours (MY2016 TDI 150).
Had a couple of "Reductant pressure too low" errors recently, popped my head under the bonnet and immediately saw a huge clump of white crystals.
I guess when it stops raining I'll clear it all off and see if I can spot where it's leaking.
Anyone know how DIY-able replacing either the injector or hose would be ?
