Octavia Reliability
Following on from my previous post of faultless reliability, ive just had to replace the four pin engine temperature sender as it has put the engine light on. Still, at a cost of
I have had two Octavia RS's. Problems encountered to date:
02 Octavia RS:
Water pump/ thermostat failure - repaired under warranty.
Coil packs (4 No.) - replaced under warranty
Indicator control unit - replaced under warranty
Coolant expansion bottle - replaced under warranty
Engine temperature sender - replaced
Loose turbo - repaired
04 Octavia RS:
Steering column rattle - replaced under warranty
light switch to glovebox - does not switch off
Center armrest trigger - broken
Window regulator - replaced (€180)
Central Convenience Unit failure - TBA
