DTC help
Can anyone help with the DTC codes below? The glow plug light just started to flash and was running ok, the car runs and feels ok but I have an MOT due next week and need to clear the DTC's, I cleared them with the scanner but came back straight away.
Thanks.
Make:
SKODA
Model:
Superb 1.6D
Year:
2013
VIN:
TMBBJ73T3D9******
Mileage:
0 km
Vehicle Software Version:
V10.06
PROFESSIONAL REPORT
System(1)
Status(
3
01 Engine Electronics
Fault | 3
DTC
System
Explanation of DTC
Failure description
Status
P010300
Mass Or Volume Air Flow Sensor A Circuit High
Active/Static
P305300
Starter Activation, Return Message Terminal 50 - Open/Short To Ground (GND)
Passive/Abiogenesis
P15A100
Transmission Neutral Position Sensor - Implausible Signal
Active/Stati
I would start by checking all of the air intake pipes / hoses and also the integrity of the air intake cover. You will need to get underneath the engine to do a comprehensive check of everything but more often than not, an air leak is the cause of such codes in that it causes a knock on effect.
Sorted, the problem was fuse 13 in the interior that wasn't making contact, the fuse read ok but after using contact cleaner on the terminals all fault codes went away immediately.
