turns over but wont start
Hi all , my sons fabia 1.4 16 valve  has developed a starting issue, it turns over but wont fire , however if you put a jump on it it fires instantly and runs fine with no dash lights. I have had the battery tested and the shop said it was ok, any ideas please?. thanks in advance. Any help appreciated
It sounds like the starter motor is weak.
It spins over ok, I suspect the battery ,its 4 years old and is onlyn used on short journeys
Solenoid? Simple check is to use an auto range DVM on solenoid. I seem to remember Sep saying that these were available. From my old days, drop across  solenoid contacts should be less that 0.5v.
thanks for that, I have replaced the battery and all seems well at the moment but I will check that when next I see him. thanks again
I have a similar issue; however, even if I use a different battery it still will not fire.  No fault codes are recorded.  The starter motor seems to be string enough to turn the engine over and the rev counter reads around 250 rpm when doing so which rules out the crankcase sensor.
Even after changing the spark plugs, I only get a weak orange spark when performing a field test by removing the spark plug, sticking it back into the coil, placing the spark plugs threads onto an engine lifting eye and then running the ignition system.  This could mean all four coils have suddenly broken at the same time, or the coil module is broken (I suspect its located under the battery but not sure, as coil wires seem to head there), or something else, relay perhaps?
I have also turned the key fully forward to prime the fuel rail and then pushed in the valve at the end of the rail but no fuel is coming out, which could indicate that the problem might be with the fuel pump (I do hear noises coming from the component that the air filter box gets pushed onto when turning the key but don't know what it that should tell me).  Does this car have an inertia switch which could have tripped thus cutting off the fuel supply?
Does anyone have a clear idea as to what the cause could be?
For anyone interested the problem was the fuel pump.  It was strange though because after three days of not being run, the car decided to start one morning and was able to be driven for around an hour but it started to stutter on the home stretch as if it was running out of fuel, and after switching it off, it did not want to start any more after that.  We then disconnected the fuel line from the front of the fuel filter and put the ignition key fully forward to prime the fuel system, but no fuel came out, and no fuel cam out when we removed the fuel lines from the rear of the fuel filter either indicating that it was the pump.
After removing the pump (removing its hose was a real pain), bench testing it with 12 volts directly to its two terminals made it work for a second or two but never again after that.  Once the new pump arrived, we bench tested it first and it hummed like a bird when given 12 volts.  After putting the pump back into the sender unit we again bench tested it from the actual four pin socket and it still worked, so we installed it, primed the fuel system, confirmed that fuel now came out of its pressure release valve, primed again and the car started right away.  Took if for a drive, allowing it to reach operating temperature before taking it above 50KMH, and it ran just fine all the way up to 100KMH.  Got home, turned it off and confirmed that it started again afterwards.
