Clutch Temperature Warning
I had a warning ping up yesterday to say my clutch temperature was high but it was OK to continue driving.
I was surprised as it's a manual car and I hadn't been maneuvering or even changed gear for a few minutes.
I've only heard of clutch temp warnings on DSG cars, does anyone know if manual cars have a clutch temperature sensor or is this more likely to be another software bug?
Could you smell hot friction material? If not, I'd suspect another (previously undocumented) bug.
Nope, and we hadn't been doing anything that would have put any strain on the clutch either.
Edited by BacktoaVRS
OK; well the only times I've got my clutch hot I could smell it.
  • 8 months later...
Did you get this issue sorted and find the cause because I believe I’m having the exact same issue
No, my car went in for checks and nothing was found, (this was after it also threw a clutch error) .
Apparently the clutch error indicated the clutch had slipped, still monitoring it but worst case could be a new clutch!
Not impressed as I've only done 14k miles and try not to do anything that would wear a clutch but apparently the warranty on a clutch is only 6k miles!
Sorry to drag this up, but I got the same, message on the motorway (ie when clutch wasn't under particular strain).
Several times "Temperature high, continue driving"
a couple of times "Temperature high, stop driving and see dealer"
Taking it into Skoda was a complete waste of time as usual - nothing recorded on the system, and cannot replicate the problem - basically like every single other electronic issue I've had with the Mk4. very frustrating. Never had a single issue with any other of my Octavias going right back to mk1.
They do not, are you absolutely sure that the error message said clutch temperature high?
No mention of clutch in those messages, what makes you think it was? Did you look at the water temperature guage? What was it reading?
Pretty useless warning if it does not specify what temperature was too high, the obvious one would be the engine coolant but I can think of a dozen other temperature sensors and none of them are the clutch.
These later vehicles are just a pi55 take :sad:
I would give you an update on what happened with mine but… I didn’t do anything other than a normal service and I haven’t had the message since. Bizarre.
I 've had the error a number of times now, I'm unable to capture a picture as it only appears for a few seconds but definitely does say clutch temperature.
Worryingly on one occasion it was also followed by clutch fault.
Skoda dealership also couldn't find any issues.
Yes sorry for confusion it definitely said Clutch Temperature high, 100%. Just while motorway driving, it's come up a few times but didn't on my most recent long trip
For what it's worth my car was a Jan 2020 when they were very new, and I've had no end of electrical error gremlins, some of which still persist - skoda say everything's fine. Others include the radio randomly switching itself off in the middle of a drive, sat nav taking two attempts to input an address, constant bonging about "take over driving" and "stay in the middle of the lane" even though I already am. Total joke. Only reason I'm keeping it now is they've stopped doing the manual vrs which is the only one I was interested in. Never had any problem with the car itself mechanical etc, and this is the first of my skodas that's ever given me any grief after owning 5 now...
I can sympathise, mine's a 2021 plate but I've also had my fair share of software issues, though since the update to SW1941 it does seem to have mainly behaved itself, apart from an occasional unexpected restart.
I also want a manual car over a DSG, I have that read that the clutches in the manuals aren't the strongest but 15k miles seems ridiculous so I hope it is another glitch.
I suspect not though, it does seem to be reproducable especially when accelerating in a high gear from low rpms which I understand puts a higher load on the clutch? I'm trying to avoid doing this, but I'm very disappointed that Skoda seem to think this is an acceptable length of life for a clutch.
If it does come to having to have it replaced, does anyone know if the dealers would fit a stronger clutch or would I need to go to a 3rd party for that? I don't see the point of replacing with the same part if this is likely to happen again!
  • 2 years later...
Wow time flies, can't believe this was 2 years ago. Well, I've still got the issue and now I can feel the clutch actually slipping too. It still only happens in high gear at highish speeds every now and then. Garage says there's nothing they can do to adjust other than to replace the clutch which is £900+. There's no cable to adjust like they did in the past apparently. But I can't really do that just on the off-chance it might fail, so presumably I just have to live in fear from now on! Has anyone else had any updates or resolutions on this issue?
Edited by Dr_Pepper
