Power steering pump
Where do I find the correct pump for my Fabia 2014ย  1.6 TD .
Can look up for you later if you message me with your VIN.
Just off to the gym now.ย
Thanks for your help will message you laterย
Hi VIN number is
TMBFL25JXE3077334.
ENGINE number CAYCY39631.
Thanks for your help.
6R0423156C is the part number suggested.
This page suggests that there are a lot of part numbers equivalent to this, but I would stick to what's suggested as a first search.
You may not wish to consider new from Skoda, the pre-VAT cost just breaks into 4 figures.
Edited by Breezy_Pete
Hi thanks for that my patience has run out with Skoda local dealers wait time for diagnostic on problem 2 month?
Hi bought a recommended scanner here's a readout pic any ideas why it won't connect to steering.thanksย
ย
Have you fitted the replacement pump yet?
ย
Wiring fault is always a possibility for no comms, either the CAN pair or the ignition switched feed on the same 4-way connector (or the fuse for that feed, though often shared with other functions. I am in a car (not driving!) just now, not sure if I can look at circuits to say what fuse, but will try.
Cabin fuse 16, I think; but that is shared with a few other things that you would know were not working if it had failed.ย
Ok thanks is the only control module on the pump or is there one on the rack
Pump only.
Is this the original pump or a replacement?
2 minutes ago, Breezy_Pete said:
Pump only.
This is the original Iam assuming that it's the pump control module that's the problem.
Yes, if the wiring is all intact.
Hi thanks for your help will try fitting a replacement pump hopefully that will solve my problems.๐Ÿ‘
  2. Tap Permissions โ†’ Notifications.
