Low engine temperature
Good afternoon all, I wondered if someone could help with an issue I have with my 2011 plate 2.0 DSG TDI-CR. The engine temperature gauge never gets above 1/4 up the scale, even if the engine has been running for a couple of hours. The engine oil temp shows around 68 - 74 degrees. Can anyone suggest where the issue might be? Car has done 61k miles.
Many thanks all, Ben
99% certain it will be the DSG oil cooler thermostat causing the problem.
Good news is the part is about £20 and can be DIY swapped out in about 30 minutes with only basic tools.
Have a search on here, there are a few guides on changing it.
Plus one for DSG stat comes up regularly on forum.
thank you all, much appreciated :)
