Yeti Greenline 2012 right hand drive, revease buzzer location
I know this topic has been aired before, but I could not find the reversing buzzer on my Greenline, that only has rear sensors.
I bought a workshop manual, be it on a CD. And it showed the location of the buzzer to be in under the left had panel in the luggage area,
and was around the area of the wheel arch. After a struggle getting the panel off, there was no sign of the buzzer. I then gave up the idea
of replacing the buzzer, but on backing into my wife's large flower pot and smashing it, and the ear bashing I got from my beloved, it was time
to find the buzzer. Another look on the internet and there was a photo showing it to be on the rear roof panel under the roof lining, and it was.
Having lost the replacement somewhere in my garage, I just disconnected it thinking the system would work without it, but no. So I bought a second
unit from eBay (made in China) connected it up, and we are back to normal with Bolero display working and the buzzer bleeping. Of course, I had to
buy the wife a new flower pot!
Have a look on this PDF. The buzzer looks like being behind  the 3. brake light.
Time to retrofit a RVC.
PDC Yeti.pdf
The buzzer is on the right-hand side rear under the head lining, to the right of the third stop light. It is held in place by
a T15 torque screw. I could not undo the screw, and had to force the fault unit off the screw. The unit has a long lead
on it, so I repositioned the new unit behind the right hand tailgate trim. (now easy to get to).
The Bolero unit will not operate in reverse display mode unless the buzzer unit is in place.
