Fault codes
Hi
I have a Mk1 Octavia that has thrown 3 lights on the dash and put up the following fault codes
01201 ABS pump voltage
00301 ABS return flow pump
01598 Dry battery voltage
Any ideas on whats wrong i have checked battery and thats fine, also goes up to 14 volts with engine running so guessing the alternator is charging.
Kev
If it was a Fabia, I'd say you should check the relevant strip fuse in the fuseholder on the battery. That's nearly always cracked when such faults show on Fabias, a nice cheap and easy fix.
Photograph said fuseholder (if there is one on a mk1 Octavia)  if unsure of what to look at/for.
yup, theres a fuseholder on octavia battery.
that youre getting 2 abs and one "battery" fault, id go with Pete's easy check first. check all the fuses.
if its not those, ABS pump itself might be dying.
whatthe details on your mk1? engine code, age, spec etc?
Withdrawn given previous posts I've just seen (missed before).
Edited by nta16
Sorry everybody it's the wife's Fabia not my Octavia, don't know why I said Octavia lol
Thanks for replies
Fabia VRS 2006
120,000
Engine BLT009599
Almost certainly a strip fuse that's cracked then I think. No.4 in your wife's car I expect.
Edited by Breezy_Pete
Thanks for help folks, all sorted broken number 4 fuse.
