Rear suspension parts
I've got a skoda superb estate 2016 2.0tdi with 148k miles on the clock.
The rear suspension is now very jumpy and thinking of replacing the springs and shocks.
Ive bought some 12.5mm springs, which will hopefully help with a low rear ride height and to carry a bit more weight.
The shocks are currently 3Q0 512 011HD so thinking of replacing them with bilstein b4 19-232363 or sachs 318 02, but I am wondering if I need something else if the ride height is slightly increased?
IS it worth replacing any other components whist the work is being done?
The bump stops will be shot and the top mounts a good idea.
What 12.5mm springs have you purchased?
Do you mean Bilstein B4 19-232362 ?
Do you mean Sachs 318 202 ?
Yes I did mean the
Bilstein B4 19-232362 or
Sachs 318 202
The springs I have bought are
KYB RA5331
It's a 2016 2wd 2.0 150ps se technology estate
2 hours ago, bassanclan said:
Yes I did mean the
Sachs 318 202
KYB RA5331
KYB RA5331 is sold to replace only OEM part number 3Q0511115AL so should be an exact match.
Although 3Q0511115AL is a little stiffer than 3Q0511115AK, it's still a standard ride height rear spring.
As you can see in the chart below, both 3Q0513049FN and 3Q0513049FP are listed as standard ride height rear shock absorbers for the Superb MK3 front wheel drive. Searching for both of these two OEM part numbers should help to find suitable aftermarket rear shock absorbers. Sachs 318202 is listed against both of these OEM part numbers, so should be a good choice.
Bilstein B4 19-232362 is not listed against either 3Q0513049FN or 3Q0513049FP.
Superb MK3 front wheel drive rear shock absorbers (1JA = standard ride height)
  3Q0513049FP Rear shock absorber     1JA
  3Q0513049FN Rear shock absorber     1JA
The gknautomotive, Kilen/Lesjofors, and KYB online spring catalogues all list 3Q0511115AK as being suitable for the Superb MK3 estate 2.0TDI front wheel drive, so going up one in the weight range to 3Q0511115AL seems a sensible choice if the standard rear springs are a little on the soft side. However, it's always worth checking what the standard springs are, as they won't always be exactly the same as what's listed in the various online spring catalogues.
Superb MK3 front wheel drive rear springs (1JA = standard ride height)
  3Q0511115AH Coil spring     1JA+0YA
  3Q0511115AJ Coil spring     1JA+0YB
  3Q0511115AK Coil spring     1JA+0YC
  3Q0511115AL Coil spring     1JA+0YD
  3Q0511115M Coil spring     1JA+0YE
  3Q0511115N Coil spring     1JA+0YF
  3Q0511115P Coil spring     1JA+0YG
  3Q0511115Q Coil spring     1JA+0YH
  3Q0511115R Coil spring     1JA+0YJ
  3Q0511115BC Coil spring
1JA+0YK
Skoda parts catalogue
https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/511/511000
VW Codes Decoder
0YA = Weight range 1
0YB = Weight range 2
0YC = Weight range 3
0YD = Weight range 4
0YE = Weight range 5
0YF = Weight range 6
0YG = Weight range 7
0YH = Weight range 8
0YJ = Weight range 9
0YK = Weight range 10
http://igorweb.org/equidec.aspx
Edited by Carlston
  • 1 year later...
Interesting,
My 2.0 tai 190 has very soft rear springs when loaded it’s not good. Just checked and label on the springs is jq0511115 AJ, coil 11.8mm in diameter , so weight 2. So no wonder it’s soggy. It’s a 2021 with 21k, so thanks for your info and I will be getting some AL springs. ie + 10%. Ian
