Sudden error codes on my Kodiaq
Hi all.
I've been having a problem, I've bought two days ago 2019 Kodiaq and before trip on a highway, there was no errors reported on VCDS.
Few hours later, I'm driving on a bumpy highway 180-190km/h and suddenly I get: ESP/ABS error, Lane assist error, Front assist error, Blind spot error, tire pressure error, ACC error...
Now by report, I've questioned speed sensor, changed it today, housing way a lot rusty and after clearing Fault Codes, everything is back. Battery was changed June/2022 for Exide EL700 EFB.
Do you have more idea what could be a problem?
VCDS
Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: Release 23.3.0 Data version: 20230228 DS346.1
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Tuesday,25,July,2023,21:23:50:00009
VIN: TMBLJ7NS2K8046611 License Plate:
Mileage: 196362km-122013mi Repair Order:
Chassis Type NS-SK37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 15 17 19 22 2B 36 3C 42 44 47 4B
52 5F 6C 6D 75 A5 BB BC
VIN: TMBLJ7NS2K8046611 Mileage: 196362km-122013miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
VCDS
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-DFGA) Labels: None
Part No SW: 04L 906 026 QT HW: 04L 907 309 P
Component: R4 2.0l TDI H25 6582
Revision: B4H25--- CVN: BEB663CA37C5C2A218229D33
Coding: 0125001203661D083000
Shop #: WSC 33361 790 00137
ASAM Dataset: EV_ECM20TDI01104L906026QT 004006
ROD: EV_ECM20TDI01104L906026QQ_AU37.rod
VCID: 0C171137A74B5EF3AF-8058
VINID: 91D49C6877A309B200106181042B7A9CF1
3 Faults Found:
17156 - Databus
U1123 00 [040] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 10
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Engine RPM: 2990.50 /min
Normed load value: 52.2 %
Vehicle speed: 39 km/h
Coolant temperature: 67 °C
Intake air temperature: 85 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 12.760 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 2.038 m/s²
34193 - Implausible Data Received from ESP Control Module
U0416 00 [040] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Engine RPM: 2768.00 /min
Normed load value: 19.6 %
Vehicle speed: 38 km/h
VCDS
Self-Diagnosis Log
Page 3
Intake air temperature: 83 °C
Voltage terminal 30: 12.740 V
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
12888 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Engine RPM: 2977.50 /min
Normed load value: 58.4 %
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0GC 300 013 L HW: 0GC 927 711 H
Component: GSG DQ381 H06 2401
Revision: 00H06V07 CVN: 74878860
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ381061 001
ROD: EV_TCMDQ381061.rod
VCID: 2D51BCB37C1137FB58-8078
No fault code found.
VCDS
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 EF HW: 5Q0 614 517 BP
Component: ESC H35 0107
Revision: 00000000 Serial number: 60079000002066
Coding: 60076A9F40240B72477D070162C449065602D0E2E046927538615078F2A94A0B00402F641A1B13111435351 Shop #: WSC 33361 790 00137
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
VCID: 79F958E3F8D95B5B84-802C
4 Faults Found:
0040 - Front Left Wheel Speed Sensor
C101A 01 [008] - Electrical Failure
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 225
Mileage: 196321 km
Date: 2023.07.25
Time: 14:05:01
0045 - Front Left Wheel Speed Sensor
C101A 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 184
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:48
16417 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 184
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:58
32993 - Control Module for Electric Parking Brake
C10E2 F0 [009] - RPM Sensor Implausble Signal
Freeze Frame:
VCDS
Self-Diagnosis Log
Tuesday,25,July,2023,21:23:51:00009
Page 5
Fault Priority: 3
Fault Frequency: 1
Reset counter: 184
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:48
VCDS
Self-Diagnosis Log
Page 6
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0503259461 Dataset Number: V03935283FE 0001
Coding: 032C0C0723
Shop #: WSC 33361 790 00134
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB.rod
VCID: 4385FA0BCA95D18B9E-8016
Rear lid opener control module:
Subsystem 1 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58600444
1 Fault Found:
12786207 - Databus
U1123 00 [008] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Park selector lever position: Not engaged and not locked
Request active: Condition not met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition not met
No active error mode: Condition met
Key signature validity: Condition met
Control Module Voltage: 14.019 V
Driver information key position copy workshop: not active
Driver information: roll warning: not active
Driver information: emergency shutdown: not active
Internal_key_position: no_message
Driver information comfort switching: not active
VCDS
Self-Diagnosis Log
Page 7
Vehicle speed: 34.6 km/h
Engine RPM: 2643.0 /min
Status of vehicle locking: Vehicle locked internally
Approach to the inside: not active
Actuation to the inside: not active
Approach to the outside: not active
Actuation to the outside: not active
Pulling actuation: outside door handle: not active
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
VCDS
Self-Diagnosis Log
Page 8
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Serial number: Y0006RKS16960
Coding: 0010000000000500018280818180000000008181000000D400
ASAM Dataset: EV_SeatMemorPasseSide 002022
ROD: EV_SeatMemorPasseSide.rod
VCID: 3D718CF3AC71A77BE8-8068
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 565 907 044 BB HW: 565 907 044 BB
Component: Climatronic H04 2002
Revision: 00001K00 Dataset Number: 0000
Coding: 1601010400011001110510080010102A
Shop #: WSC 33361 790 00111
ASAM Dataset: EV_ACClimaBHBVW37X 006147
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 5CB72177572B8E73FF-8008
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Subsystem 3 - Part No SW: 5Q0 907 659 C HW: 5Q0 907 659 C
Component: G238 _AQS H30 0119
Serial number: 82833806
1 Fault Found:
263425 - Air Quality Sensor
B10AF 04 [008] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 225
Mileage: 196318 km
Date: 2023.07.25
Time: 08:15:23
Voltage terminal 30: 13.8 V
Outside temperature: 24.5 °C
System run time-Engine running time: 159 s
System run time-Terminal 15 on: 255 s
VCDS
Self-Diagnosis Log
Page 9
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 086 BR HW: 5Q0 937 086 BR
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: 865803011901NT Dataset Number: V03935287MQ 0001
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019.rod
VCID: 0B15122BA24559CBA6-805E
Wiper motor control module:
Subsystem 1 - Part No SW: 566 955 119 HW: 566 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS326 181202 051 0910
Serial number: 887353F0401833602848
Coding: 164DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY19M01D15H08M34S13
Coding: 00885D
Humidity sensor: interior:
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 AG HW: 5Q1 953 569 A
Component: Lenks.Modul H13 0170
Serial number: 0100201220180C302055
Blower 1 for left front backrest:
Subsystem 5 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V512 LLR1SLvL H01 0012
Serial number: Q98AI26001154
Blower 1 for left front seat cushion:
Subsystem 6 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V514 LLR1SKvL H01 0012
Serial number: Q98AI26700303
Blower 1 for right front backrest:
Component: V516 LLR1SLvR H01 0012
Serial number: Q98AI26001155
Blower 1 for right front seat cushion:
Subsystem 8 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V518 LLR1SKvR H01 0012
Serial number: Q98AI26501502
2 Faults Found:
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
VCDS
Self-Diagnosis Log
Page 10
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 186
Mileage: 196321 km
Date: 2023.07.25
Time: 14:12:01
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.3 V
Outside temperature: 25.0 °C
657668 - Fan 1 for Left Seat Cushion
B14CB 31 [008] - No Signal
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:11:52
Terminal 15 status: On
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.2 V
Outside temperature: 25.5 °C
VCDS
Self-Diagnosis Log
Page 11
VCDS
Self-Diagnosis Log
Page 12
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 3Q0 919 294 C HW: 3Q0 919 294
Component: PDC 8 Kanal H08 0038
Serial number: 002411187498002 Dataset Number: V03935283YL 0001
Coding: 0071655811
ASAM Dataset: EV_EPHBO18VW3260000 007021
ROD: EV_EPHBO18VW3260000.rod
VCID: 397998E3B8599B5BC4-806C
4 Faults Found:
13637411 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
13637424 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
13637426 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
13688835 - Databus
VCDS
Self-Diagnosis Log
Page 13
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
VCDS
Self-Diagnosis Log
Page 14
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 Q HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0342
Dataset Number: V03935294LV 0001
Coding: 320467C15CFF8728749C814530408700000000000000000000
ASAM Dataset: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 428BFF0FD58FD88395-8016
8 Faults Found:
0803 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:50
Voltage terminal 15: 14.0 V
Control Module temperature: 52 °C
Vehicle speed: 2.14 m/s
Longitudinal acceleration: 0.44 m/s²
Adaptive distance regulation: status: ACC_irreversible error
2101 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_reversible_error
0810 - Databus
VCDS
Self-Diagnosis Log
Page 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Adaptive distance regulation: status: ACC_StandBy
0815 - Databus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
2102 - Databus
U1122 00 [008] - Implausible Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Longitudinal acceleration: 0.28 m/s²
VCDS
Self-Diagnosis Log
Page 16
0862 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 33
Reset counter: 226
Mileage: 196321 km
Date: 2023.07.25
Time: 14:03:03
Voltage terminal 15: 12.9 V
Control Module temperature: 42 °C
Vehicle speed: 6.84 m/s
Longitudinal acceleration: 0.03 m/s²
0837 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
0863 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
VCDS
Self-Diagnosis Log
Page 17
Voltage terminal 15: 13.9 V
Longitudinal acceleration: -0.03 m/s²
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PSDQF4M Dataset Number: V03935285DY 0001
Coding: 98CCC0C0000000005C5400CF000840000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 454 000 501 19
Component: SideSensor_Df 008 0887
Serial number: 35700000000AFB19563W
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 454 000 501 19
Component: SideSensor_Pf 008 0887
Serial number: 3580000000092D19563L
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 454 800 901 19
Component: SideSensor_Dr 301 0148
Serial number: 35100168D5917000000G
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 454 800 901 19
Component: SideSensor_Pr 301 0148
Serial number: 35200714867170000008
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 454 800 212 18
Component: FrontSensor_D 304 0149
Serial number: 35500699AE916000000Y
Coding: 2D2D2D
VCDS
Self-Diagnosis Log
Page 18
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 565 920 790 A HW: 565 920 790 A
Component: KOMBI 508 1691
Coding: 04A4001CEF8400080188630B5001000880000000
Shop #: WSC 73430 031 00137
ASAM Dataset: EV_DashBoardVDDMQBA0 001026
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 1C37617717ABCE733F-8048
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 20121810523427 Dataset Number: V03935289UD 0001
Coding: 0B0100045F087300EB1322DA1A0F00010001070000000000000000000000
GVL: 01C63C000800060040FC80008002C80000000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013025
ROD: EV_GatewNF_VW37.rod
VCID: 6ED37BBFB1970CE321-803A
Generator:
Component: 0-01-13-01-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 3V0 919 719 F HW: 3V0 919 719 F
Component: E221__MFL-PR6 H03 0170
Serial number: 000000000C0502081218
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5QA 915 181 C HW: 5QA 915 181 C
Component: J367-BDMConti H03 1051
Serial number: 7588610300190110039E
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 H HW: 5Q0 907 155 H
Component: U13DCAC H25 0780
Serial number: 5029314
VCDS
Self-Diagnosis Log
Page 19
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00026.11.18 Dataset Number: v1260x015G0 0000
Coding: 0101
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4C97D137E7CB1EF36F-8018
1 Fault Found:
16656 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:48
VCDS
Self-Diagnosis Log
Page 20
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000405456017
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 3365AACB9A35610B0E-8066
2 Faults Found:
13637378 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:50
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: Not operated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: On
Clamp 15: On
Clamp 15 Status: valid
Remote Start: not active
Driver door: to
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
VCDS
Self-Diagnosis Log
Page 21
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c cnd false
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: No
Lifestate: Immobilizer download obtained
Learn mode: Adapted
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 39.79 km/h
UBat internal: 13.2 V
UMotorBridge: 7.2 V
Lock condition engine speed: Condition not met
Lock condition clamp S: Condition not met
Lock condition clamp 15: Condition not met
Lock condition E2E clamp status: Condition not met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition not met
Lock condition E2E vehicle speed: Condition not met
Lock condition timeout vehicle speed: Condition not met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition not met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition met
Lock condition difference distance pulse: Condition not met
13637386 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 226
Mileage: 196319 km
Date: 2023.07.25
Time: 08:16:56
ESCL locked: No
ESCL unlocked: Yes
VCDS
Self-Diagnosis Log
Page 22
Clamp S: OFF
Clamp 15: OFF
Driver door: For
Clamp Request: No
Highside unlock: No
I2C overflow: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C error sda: No
Coco reset: No
Coco supply: On
IMS responded: Yes
Learn mode: Adapted
Vehicle speed: 0.00 km/h
UBat internal: 12.0 V
UMotorBridge: 6.5 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition met
Lock condition clamp 15: Condition met
Lock condition E2E clamp status: Condition met
Lock condition selector lever position parking: Condition met
VCDS
Self-Diagnosis Log
Page 23
Address 36: Seat Mem. Drvr (J810) Labels:* None
Serial number: Y0006RKR35990
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide.rod
VCDS
Self-Diagnosis Log
Page 24
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0504295423 Dataset Number: V03935261EB 0001
Coding: 02011103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0503473162
Coding: 020111
2 Faults Found:
337760 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
338048 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 226
Mileage: 196321 km
Date: 2023.07.25
Time: 14:03:03
VCDS
Self-Diagnosis Log
Page 25
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000359556549 Dataset Number: V03935292KQ 0001
Coding: 00150920DE00020000001100
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
VCID: 489FED27F3B3F2D34B-801C
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000026314577
Coding: 010200
VCDS
Self-Diagnosis Log
Page 26
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5QF 909 144 B HW: 5QF 909 144 A
Component: EPS_MQB_ZFLS 507 5582
Dataset Number: V03935289PK 0001
Coding: 91170000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
VCID: 4999E823E8B90BDB54-801C
3 Faults Found:
20740 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Motor status: 02
System status: Driving mode
Supply voltage: 14.00 V
Temperature: 52.0 °C
KFC: 51
KFA: 00 04
Freeze frame conditions: 21
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 13.89 V
uAdSensI_SwitchedKl30_xdu16: 13.93 V
NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
NoInitCause_RackPos_Rohwert: 00 00
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_KMN_RACKPOS_SET: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_WHLSPDPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
19716 - Databus
VCDS
Self-Diagnosis Log
Page 27
Freeze Frame:
Fault Priority: 6
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Motor status: 02
KFC: 4D
KFA: 00 04
uioUdNotFilt_xdu16: 14.08 V
uAdSensI_SwitchedKl30_xdu16: 14.13 V
20228 - Databus
Freeze Frame:
Fault Priority: 6
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Motor status: 02
KFC: 4F
KFA: 00 04
VCDS
Self-Diagnosis Log
Page 28
uioUdNotFilt_xdu16: 13.92 V
uAdSensI_SwitchedKl30_xdu16: 13.96 V
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1JJE06D45Z Dataset Number: V03935252KE 0001
Coding: 0323160000AA002AAA0000000000
ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
ROD: EV_AMPMst16C4Gen2ALPI.rod
VCID: 59B9386358197B5BE4-800C
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
VCDS
Self-Diagnosis Log
Page 29
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000361739342 Dataset Number: V03935292KV 0001
Coding: 00150120DE00020000001100
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
VCID: 479DEE1BFEADFDAB42-8012
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000026299793
Coding: 190200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 864 C HW: 5Q0 035 864 C
Component: MU-S-N-ER H41 0475
Serial number: SKZAZ2W0224754 Dataset Number: V03935295LD 0001
Coding: 03231601000000004111000200000A002F020BE4012084008E
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW37.rod
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 565 919 605 B HW: 565 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: SKZ6ZHW0102120
Data carrier:
Subsystem 2 - Part No SW: 5L0 051 236 AH HW: -----------
Component: ECE1 2018/19 --- 1030
Serial number: --------------------
VCDS
Self-Diagnosis Log
Page 30
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG044248 Dataset Number: V03935265RR 0001
Coding: 04231601A20FA0000060400C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 P HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0266
Revision: -------- Serial number: 32274628700000 Dataset Number: V03935272MU 0001
Coding: 1B08
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW37.rod
VCID: 4581E413C4A1EFBBB0-8010
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: -------- Dataset Number: V03935285TV 0001
Coding: 03231601EA421A0D3F1C9E020045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW32.rod
VCDS
Self-Diagnosis Log
Page 31
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3QD 980 654 A HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 1611
Serial number: 06121841P11790 Dataset Number: V03935294JU 0001
Coding: 0203070600000401002213548150A90098000E20000000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
2 Faults Found:
1123173 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:49
Control Module temperature: 40 °C
Outside temperature: 24.0 °C
Vehicle speed: 35.27 km/h
System run time: 417.8 s
Voltage terminal 15: 13.7 V
mid: 02 E0
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 1
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 1
4195331 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 226
Mileage: 196317 km
Date: 2023.07.25
Time: 08:14:50
VCDS
Self-Diagnosis Log
Page 32
Vehicle speed: 38.00 km/h
System run time: 418.8 s
Voltage terminal 15: 13.8 V
mid: 02 A7
Software_Info_4: 1
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 1
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
End-------------------------(Elapsed Time: 07:17)--------------------------
I take it you have changed the front left ABS sensor, yet it still shows up in this scan as faulty? You may have fitted a faulty, new sensor. Or the connection plug is not making proper electrical connection. The ABS sensor housing may have some rogue flakes of rust in the bottom. Or you may have a break in the wiring to that sensor. The faults after a bumpy road might indicate that.
Odd that so many of the minor faults show a frequency of 10 events. This implies they are all linked somehow. The year old battery is unlikely to be the issue but a quick check of all major connections - and the alternator connections - might be worth doing. Looks like you could do with an updated VCDS interface to get the most information out of this.  Clear all DTCs and report back.
  • 8 months later...
What was the issue / resolution as this has happened to me in my kodiaq today travelling back from southern France - no power steering  either & lots of sensor failures
Speed sensor on front left wheel. A lot of work and fuss but everything was fine afterwards.
Thank you Docx - I had feared it was the SW update I had done 2 weeks ago , others had mentioned battery but I’ve put in a new one in Jan from Costco so I doubt it’s that.
will ask garage to check it all over.
Check the battery state of charge at the battery terminals.  If the battery wasn't 'coded' or 'coded' correctly it might be in a low state of charge despite being new , a battery is just a store and the store can be depleted even if new.  Whilst you are at it also check the battery terminal clamps are also tight and clean, it's amazing the number of places/people that are sloppy about doing such easy work.
Many owners don't realise a battery can be low even though it starts the engine and the lights seem bright enough, you get warnings then items unavailable by the time the engine is difficult to start the battery could be beyond full recovery, hopefully not on such a recent battery.
If the battery is low then fully recharge it with an appropriate charger maintainer, a long. low, slow recharge is usually better than a shorter, higher, quicker recharge.
If you're in Northampton send me a direct private message through the site and I can check the battery state of charge and installation if you want/need me to.
Sorry I no longer have access to a scan tool as my neighbour has moved away but IF it is the battery once it is fully recharged it is very easy for you to get rid of the warnings without any tools - but of course if there is also a separate issue with a speed sensor then some or perhaps even all of the warnings will remain but any electrical or engine starting problems are helped by not have the battery in a low state of charge.
Edited by nta16
typos
Hi Nigel,
Thanks for the steer, I will check but I am pretty sure the battery is okay - as said, its brand new and I fitted it myself. (But I don't know what coding is - so I didn't do that) - but it did have a SW update before travelling out_ as I had driven to southern France 2 weeks prior and was 3 hours into a journey back home, so if it's the battery not charged after that, then I'd suspect the alternator or something else causing the issue?
But its back in the garage this week for them to check it out so I'll let you know.
Rob
Was the replacement battery you fitted exactly the same type and capacity as the original?
Hi Rob, no problem.
As Warrior193 has mentioned, if the battery is the same type (EFB) and about the same Ah and previous battery was 'coded' correctly then hopefully the new battery is fine, do bear in mind for the future even if the battery is new/newish it's still just a store so can be depleted but if not flogged to death should more easily fully recover with charging.  As long as the VWSkoda updates aren't like some from Microsoft hopefully you're alright with that.
The strong money is on wheel sensor and with all the VW computer programs being so complex and intertwined (and far too intrusive for me) a small fault in one area can affect a load more, apart from perhaps the start/stop I can see all being connected - be interesting to get it confirmed though.
Thanks guys,
My battery replacement was a BOSCH 12V 70Ah 760A so a bit more strength than the original - I tested the voltage and its 12.57volts - and the terminals are tight on so I dont think its that and its had two 16 hour runs too and from france so should be okay?? I don't know how to code it - not sure what that is so I'll mention to the garage about it??
The main error seems to be ESC failure then tyre pressure - then all the other ping in, then as you start to drive more error codes come up ESC starts flashing and it affects the driving until that light stays on hard which is usually within the first few hundred yards.
The power steering stops, stop start stops, the reverse camera stops loads and loads of errors come up TBH.
Parking pilot, intelligent lights, etc etc loads that seem totally unrelated to ESC..??
Depends when the measurement was taken but 12.57 at the posts a number of hours after charging sounds very good.
The rest, not so good.
As the garage will have a scan tool plugged in they can check the battery 'coding' too.
Below from my wife's car gives you an idea of battery 'coding'.
All that matters is:
  • a) the Ah is correct (or perhaps near enough) - 59 and 60 below,
  • b) the serial number changes if you are recording a new battery - from 1111111111 to 1111111112 below,
  • c) important - the battery type is correct, EFB or AGM (called "fleece" by VW) - from EFB to "Fleece" (AGM) below.
The manufacturer of the battery is of no importance now, it was for VW's records.
Edited by nta16
Changing battery causes a lot of lights that usually dissappear after few kilometres.
By my experience, solving problem on modern cars by "hit and miss" method is really expensive. This are very sensitive machines with a million sensors. Without some kind of OBD diagnostic analysis (you can find cheap ones on ebay or Aliexpress) it's simply walking in the dark blindfolded.
A basic scan tool may give a start many times but I would say for the very complex VW computer programs you want more than a generic OBD scan tool you want a good scan tool with specific programs for your VW product otherwise the information may be too general and even have error(s).
Using a good scan tool is often necessary but the results still have to be interpreted correctly, not always will the scan tool  give you the instant answer, plus using a scan tool or not the other basics of the car and diagnostics need to be carried out to very often fully successfully resolve things.
It's always been that you want the car battery fully charged before carrying on extended tests to sort out engine starting and electrical issues but it is more so with more modern cars.
Hi All
well it wasn’t the battery it was actually as was above the front right hand speed sensor and the wheel bearing…. The timing marks had been scrapped away so the garage replaced the timing sensor and the wheel bearing cleared all error codes and all is now fine with it..
thanks for all your support and suggestions very weird that a speed sensor can cause so many unrelated error codes… but that’s modern tech for you….
9 hours ago, RoBex said:
Hi All
Not so weird when you think about it, most or all of the errors displayed in your case have a vehicle speed component related to them - I.e. stop-start reengages only after the vehicle has moved a certain distance and speed since the last stop, TPMS and ABS/ESC are looking at wheel rotation rate, etc.
Edited by Warrior193
correction
As put, the computer programs are very complex and intertwined, as put, speed and braking are related to so many systems on/in the vehicle.  Which is why you don't want to let the car's battery power drop to them, they don't like it and will make you suffer for that mistake.  And that's not allowing for any errors or omissions in any of the vast amounts of computer programming on the vehicle.
In the last week my wife told me it had finally happened, she was in town driving slowly and the front collision thing jumped on the brakes and threw up a warning for no apparent reason then she saw a bag blowing by in the wind, I'd predicted wrong I thought that would happen but with a large leaf.  I might have been right when previously she told me the front anti-collision thing apparently said it was unavailable and later became available again.  The "amber triangle of doom" dash warning light has come on a couple of times and I've found no fault and it's not bothered returning again.  Then a couple of other times lit up too late when the issue has already been noted by the driver (but perhaps a good reminder for some non-drivers that passenger behind the steering wheel of the moving infotainment machine).
I think it was Toyota (of all manufactures!) that had a model go into limp mode at a reported failure of brake light, but they sorted that.  Telsa, computer experts, well where do you start with their cars and computer glitches (brain-farts, human or electronic) obviously as computer people they know all are entirely the fault of the users and not their machines or programming.
