Knocking noise
Hi everyone I have a 2016 skoda fabia it has developed a knock from the drivers side front wheel, I am totally stuck with it now as I replaced a lot of parts through trial and error, it only knocks when going over light bumps and goes away when braking, it really does sound like something is hanging off, so far I have checked every thing on both sides for play and movement the parts I have replaced are, both front drip links, main hub unit, wheel bearing, lower arm with ball joint, front discs and pads, removed and checked the drive shaft and removed both track rod ends to check any play In the rack, I need major help as I'm at a loss with it now any help will be greatly appreciated πŸ˜€Β
Also changed the strut, spring and top mount, and whilst making sure everything is tight and done up πŸ˜€
