My 2023 MINI Cooper S Level 3 Electric leased from Motability which will be with me for 3 years & now a 2021 MG5 as a dog wagon.
It's fine. From 100% and back country roads climbing and coming back down in D setting it was showing 4.7 miles on leader regen. Sitting checking, In Sport it shows 151 miles range and in ECO 189. Showing this once back home.
  • Replies 393
  • Views 38.4k
  • The tyres got a good few miles today to get the newness off them and then a good try out tonight in torrential rain in Aberdeen on roundabouts and then up the A90 on roads that were flooding. The
  • Winston_Woof
    Winston_Woof
    and at least twice the hassle as an ICE. I can get 600 miles + from a 5 minute fill up of my Superb and even if I m down to a quarter of a tank (which is where I generally fill back up) that's st
  • Postie came. Ready.
Plugged into 3 pin after 26 miles and showing this. 88% and 185 miles available.
Edited by Ootohere
You running 10A or 13A on the 3 pin ?
10 amp. After midnight.
Michelin CrossClimate 3,s going on Saturday.
Surprised that they are cheaper at present than CrossClimate 2,s or +.
205/60 R16 V 96
Edited by Ootohere
  • Guest_ changed the title to My 2023 MINI Cooper S Level 3 Electric leased from Motability which will be with me for 3 years & now a 2021 MG5 as a dog wagon.
205/60 R16 V 96
I had a 10A but saw a cheap multi amperage version which can do 13a and actually can be set to 16A in one is EU or can get house socket converted to female Commando socket.
@lol-lol The one i have can be set to 13 or 16 amp.
I will take the car to Braemar tomorrow and then charge at InstaVolt after 8.pm to see what the charging speed is like.
Edited by Ootohere
205/60 R16 V 96
Where are you getting them from - is it somewhere local or national / on-line as I've started looking for All Seasons for the Kodiaq but in a 235/55/R18 100V (or above)
ATS Euromaster,
& i get a further discount on the £125 each fitted. 60 Club.
ATS & Halfords have a very good price / discount on Goodyear Vector 4 Season Gen 3,s.
Edited by Ootohere
Efficiency has been good. Cross Climate 3,s on. I will leave the pressures up until I see how much difference if any with these.
Edited by Ootohere
MG5 good budget ev estate with plenty of go go , to much some times as I used to wheel spin 🤭
Not much difference between eco and standard on kwh
Gave mine up as it was to low for my mum and brother to get in and out of and was causing me left leg pain due to lounging seat position
Mine was a 2022 pre face long range excite in silver
Also why didn't MG use psi for tyre pressures , you can go between C and F on temp
Edited by Redestate
@Redestate My left foot is doing the accelerator and brake pedal.
Eco is just fine in town.
3 things to select as driving off from home. ECO, max regen & Autohold.
As to Fahrenheit, that means nothing to me as i have lived my life with Celsius, PSI, Miles & MPH / MPG.
kW & kW/h is fine, but thought of how many miles from them.
I was going to keep the MINI at least until after this winter if not til August when due handing back.
It p!$$ed me right off last night, well not the car but the Phone App.
It never Logged me Out, it deleted it's self. Remote info gone.
I have not Re-registered with VIN etc. So i was charging last night and checking charging started and no connection to car. No charging info, doors locked etc but it new its location, unless that was my phones location.
The MG has no phone App, but i am OK with that as the car starts charging and is accurate enough at when will be charged, and i do not need to go to 99% as often as i needed to with the MINI.
Leaving on 7 or 11 AC chargers.
Edited by Ootohere
As a car how are you finding the MG5 , ? I liked the boot size and you could get a mobility scooter in there without taking motor bit off which I have to in Enyaq ,
And I must admit I've just been on auto trader looking at low priced second hand ones , and my god has the price dropped, Tempted aint the word for a second car
Edited by Redestate
@Redestate it is KISS which i like, controls nice and straight forward.
HVAC damn good.
Seat fully down and as far back as is the steering wheel is perfect as are the pedals without me adjusting them.
Easy in and out. I am happy enough. All in £11,000 with Insurance, extended warranty, & new tyres.
When the 6 months VED is up i will change to Disabled Class and use VED Exemption on it unless i get some ICE vehicle with high VED & use on that. Fine for taking into LEZ / ULEZ,s.
Edited by Ootohere
Hi George,
Does your Mini's range start dropping when temperature starts to go below 15c ?
We find mileage prediction range very good.
Do you charge to 80, 85, 90, 95 or 100 % summer or winter or same ?
I charged to 100 % or 98/99 % nearly always. Always before heading off on trips.
DC or AC. It only shows between 108-118 even in warm weather.
It would do more but was most efficient between 15-20 *oC.
I could still get 100 miles with some range left at as low as -10*oC.
The only time i would not charge to full is if the charger was very expensive and there was enough to get me to my destination and then cheap charging.
Usually on my way homewards and needing just about 70 miles, and also if a charger had a max 40 minutes stay and i had enough charge at the charger charging slow but at a stupid tariff.
Local BMW dealer charged our Cooper E to almost full 10p % charge when we picked it up but guide seems to say 80 % charge "normally" but I have noticed that 80 % had dropped from being 145 miles to closer to 135 miles as the temp is dropping down to 10c at night.
Neighbour opposite has a BMW X1 3 something, supposedly equivalent to a 3 litre ICE, but he seems to be under impression that regikarly charging to 90% is ok.
Thinking of setting car to 90 % if it drops much further. Also was going to look in to if car could / should to second phase of charging at noon as my lad sets of at 1pm so battery and cabin pep just before leaving might help.
He is only doing about 80 miles from Worcester to Gloucester recovery day but the spare range is dwindling as weather gets colder and if he gas to do a diversion if M5 up the creek. He is not very switched on with hypermiling.
There is a software up date waiting to be run I see which changes tge setup so it can start in Green Eco mode whereas before it started in Core mode and you had to set it from Core to Green after starting off. Still quite nippy in Green I expect not like my Zoe which is like an petrol car with two plug leads pulled off when in Eco. Scenic is good in Eco as can do 72 moh indicated so a good licence saver. Mini will do 100 indicated even in Green mode I gather abd get there respectably quickly.
Still loving the Mini as it is so fun one can forgive it the limited range.
I could have it charging pre 7 am and at 100% and showing 104 miles range, say -2*oC, that was on the phone app.
Get in the car and not pre conditioned and on start up it might be showing 106 miles, then i set off and 60 mph roads and a few 20 and 30 mph villages it has 80 miles range left after 30 miles.
(Pre heating / deicing the car for 5 minutes before unplugging it made no difference to range showing on app but the dash might show more miles range. The demisting last winter was not working properly as i only found out when they said it needed the warranty work.
But i never have Heating set higher than 18*c other than maybe for a few minutes clearing the glass / windscreen. Heated seat on maybe for 5 minutes and not needed on again.
Dipped headlights always on in winter.
4 degrees C. Heading to the hills. A lovely morning but torrential rain forecast later.
Edited by Ootohere
Clova Hotel new addition.
