avacab
Hello everyone my name is Glynn.This is the first i have wrote to you.But i have a big problem.
Could anybody help me please.I have octavia sdi and i am having problems with my indicator stalk.I don,t know how to remove the stalk.
post your problem in the Octavia forum you will get someone who knows to tell you how to do get it off
Welcome to BRISKODA :thumbup:
Welcome.
To remove the stalk you need to remove the cowling round the steering column. However to remove this is quiet tricky as you have to remove the Steering Wheel to get them removed.
Briefly, you need to do the following:
Unclip the air bag from the steering wheel
Remove the bolt from the center of the slpined shaft
Remove the steering wheel and airbag assembly
Unscrew the 4 screws that retain the cowling
Unscrew the clamp
Slide the stalk off the shaft.
Take a look here for the procedure on a Golf (that is basically the same) http://homepage.ntlworld.com/dgace/control_stalk.htm
