What cars does the fabia VRS share the wheel hub with
What cars does the fabia VRs share its steering knuckle/wheel hub with. Need a new one and I’m not sure which ones fit
Tons of VAG group cars with 288 and 312 mm front discs, the scrapyards are full of them, they are handed tho' and if you've stripped one of the caliper carrier threads it's easier and cheaper to simply helicoil it, you don't even have to take it off the car.
  • Sponsor
If that ^ doesn't sort your problem, then start by knowing the part number of what you're looking for.
Left or right?
I need the left one
  • Sponsor
6Q0407255S then (last character is an S, not a five).
Thank you :)
Ibiza, Polo and Fabia share the hubs. Careful though, there's two sorts. Most fabias use the FSIII calipers so have the carriers built in the hub. The VRS uses a bigger caliper and a different hub. If you're getting them off an Ibiza, its a bit of a lottery which have which brakes.
Edited by StevesTruck
