Battery problem again
On 06/09/2023 at 07:57, langers2k said:
Glad to hear the faults have gone for now.
I expect everything I need is probably inside the history log. Can you add it as an attachment?
Hi @langers2k, have you managed to look at those files that i have uploaded. My light bulbs temperature rise quite high and then they come back to normal i guess. Don't know why its happening. Any idea?
  • Replies 213
  • Views 28.3k
  • Alternators in recent cars with start/stop will not put out a constant 14.5V, so are no longer easy to test. An independent test of the battery at a non-Halfords establishment is a good idea.
  • Correct it, so the BMS knows what new battery the muppets at Halfrauds have fitted.
  • If you have altered coding in another Module then that may be your problem. Modules not shutting down when the ignition is turned off.   Its time for you to measure the current drawn from th
Not had a chance yet. I'll report back when I do.
What is the high temp and the normal temp readings?
I wouldn't know what's the highest and lowest temp..so far i saw the temp as low as 31 and as high as 57.
I'm just wondering if that is their normal temperatures, did it actually flag up a high temperature warning message or did sort of scroll through settings and you noticed the temps changing?
I might have taken screenshots before changing/toggling the options back in 3months ago (when head light levelling sensor was snapped). I may have a full scan report saved as well when there was no fault at all. I have to check my emails for that.
Would these be any helpful!
It doesn't flag anything up in the dash. When i scan the car two fault codes appear which I uploaded above..it just happens when headlights kick in at night time. I think temperature starts from high and slowly goes down to 30s and then i can delete the fault codes. Temp doesn't go up again.
Well as I don't have LED headlights, I'm unable to comment any further, maybe Langers2k might know more about them.
57'c certainly doesn't feel hot for a LED in what could be 30'c ambient temperatures at the moment. Can't say I've ever checked what temperatures mine hit so I don't have much context for 'normal'.
Looking at 4B, the only obvious adaption channel that differs is "Presentation run dynamic AFS light" which should be 'not active'.
For reference, these are the stock values for my car and I'd expect yours to be the same, I've bundled some values together to make it easier to read. Feel free to compare against your own and check they match. I've hidden them in spoilers to make my post more readable. There are loads of differences between our cars (expected) but nothing is standing out.
These are 4b:
Spoiler
IDE00001-Production mode,not active
IDE00820-Activating and deactivating all development messages,not active
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection,Yes
IDE01996-SFT00041-Installation list: specified installations-Light Control Left,No
IDE01996-SFT00057-Installation list: specified installations-Light Control Right,No
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Yes
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes
IDE02332-Deactivate production mode,0
IDE03641-Presentation run dynamic AFS light,not active
IDE03642-Presentation mode,not active
IDE03679-Adaptive light functions,active
IDE03787-Activate left/right hand drive switch-over,not active
IDE08418-Matrix light: total dimming,100 %
IDE09156-Matrix headlamp: function at standstill,not active
ENG124608-Order_Reference_Run_Activation_Effect,No dependency
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled
ENG103979-Reference_Run_Start_Condition,Engine start
Grouped stuff
Bit pattern of individual segment activation: left headlight-LED, all OFF
Bit pattern of individual segment activation: right headlight-LED, all OFF
Rear seat fan: characteristic curve-Level, all 0 %
As for 09, I've attached the obvious headlight related channels below but I can't see any glaring errors with your current values. Please note, VCDS calls them "Stationary cornering lamp" whereas OBDeleven calls them "Static AFS light".
Spoiler
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Parking light right
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset,-0.3 °
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit,25.0 %/s
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt,both sides
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold,0.0 km/h
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur,100.0 °C
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur,95.0 °C
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel,65 °
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur,80.0 °C
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel,40 °
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold,40.0 km/h
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift,ECE R119
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht,15 min
@langers2k
Following are the full scanned copy when i had no faults in my car.
OBDeleven data log
Date: 2022-02-07 22:11
    VIN: TMBBC7NE9J0155483
    Car: Skoda Octavia
    Year: 2018
    Body type: Estate
    Engine: CZDA
    Mileage: 97945 KM
01 Engine
    System description: R4 1.4l TFS
    Software number: 04E906027HD
    Software version: 3742
    Hardware number: 04E907309BH
    Hardware version: H26
    ODX name: EV_ECM14TFS01104E906027HD
    ODX version: 001007
    Long coding: 01250032232401080000
    Trouble codes:
        P030000 - Random/Multiple Cylinder Misfire Detected
            static
                Date: 2022-02-07 20:11:08
                Mileage: 97895 km
                Priority: 2
                Malfunction frequency counter: 1
                Unlearning counter: 255
                Engine speed: 703.00 1/min
                Normed load value: 14.1 %
                Vehicle speed: 0 km/h
                Coolant temperature: 94 °C
                Intake air temperature: 41 °C
                Ambient air pressure: 1020 mbar
                Voltage terminal 30: 13.004 V
                Dynamic environmental data: 20965011BE000E13F481CDF40681F4463410D3000414B40E10
        P030300 - Cyl.3 Misfire Detected
            static
                Mileage: 97895 km
                Priority: 2
                Dynamic environmental data: 209650F44634F40B1D1010008B14B40E101199100017460001432100
02 Transmission
    System description: GSG DQ200G2_M
    Software number: 0CW300041B
    Software version: 1006
    Hardware number: 0AM927769E
    Hardware version: H05
    Serial number: CU501708186136
    ODX name: EV_TCMDQ200021
    ODX version: 001001
    Long coding: 0014
    Trouble codes:
        No trouble codes found
03 Brakes
    System description: ESC
    Software number: 5Q0614517AM
    Software version: 0312
    Hardware number: 5Q0614517AB
    Hardware version: H25
    Serial number: 62267000000730
    ODX name: EV_Brake1UDSContiMK100ESP
    ODX version: 036010
    Long coding: 24078A9124252171407B060840C6242451248402600224723021F070C002430000000012121212B8586C384E4484EE
    Trouble codes:
08 Air Conditioning
    System description: Climatronic
    Software number: 5E0907044AP
    Software version: 2001
    Hardware number: 5E0907044AP
    Hardware version: H04
    ODX name: EV_ACClimaBHBVW37X
    ODX version: 006146
    Long coding: 0111000400011001100500080010102A
    Trouble codes:
09 Central Electrics
    System description: BCM MQBAB M+
    Software number: 5Q0937084CP
    Software version: 0253
    Hardware number: 5Q0937084CF
    Hardware version: H36
    Serial number: 01001723702021
    ODX name: EV_BCMMQB
    ODX version: 018001
    Long coding: 000000000000000000000000000000000000000000000000000000000000
    Subsystems:
        System description: WWS371 170628
        Software version: 0915
        Hardware version: 051
        Serial number: 887253F0401717901087
        Long coding: 164DDD
        System description: RLHS
        Software version: 0105
        Hardware version: 047
        Serial number: S9Y17M08D31H21M34S36
        Long coding: 00885D
        System description: Sensor, DWA
        Software version: 0316
        Hardware version: 005
        Serial number: 000000000ZY171431WXQ
        System description: Sirene, DWA
        Software version: 0314
        Serial number: 00002856223971443259
    Trouble codes:
13 Adaptive Cruise Control
    System description: ACC BOSCH MQB
    Software number: 5Q0907572J
    Software version: 0654
    Hardware number: 3QF907572
    Hardware version: H10
    ODX name: EV_ACCBOSCHVW416
    ODX version: 002006
    Long coding: 3300608141FFC728949C810500400600000000000000000000
    Trouble codes:
15 Airbag
    System description: Airbag VW21
    Software number: 3Q0959655BH
    Software version: 0703
    Hardware number: 3Q0959655BH
    Hardware version: 006
    Serial number: 003W4PGL3JQK
    ODX name: EV_AirbaVW21TS6VW48X
    ODX version: 001014
    Long coding: 98CCC000000000005C5400CC008800000065
    Subsystems:
        System description: SideSensor_Df
        Software version: 0887
        Hardware version: 008
        Serial number: 3570000000055099982J
        Long coding: 2D2D2D
        System description: SideSensor_Pf
        Serial number: 35800000000A7794082K
        Long coding: 2D2D2D
        System description: SideSensor_Dr
        Software version: 0148
        Hardware version: 301
        Serial number: 35100BEB2D610000000O
        Long coding: 2D2D2D
        System description: SideSensor_Pr
        Serial number: 35200C5B70611000000A
        Long coding: 2D2D2D
        System description: FrontSensor_D
        Software version: 0149
        Hardware version: 304
        Serial number: 3550027C7C710000000I
        Long coding: 2D2D2D
    Trouble codes:
16 Steering Column
    System description: Lenks.Modul
    Software number: 5Q0953521T
    Software version: 0235
    Hardware number: 5Q0953569A
    Hardware version: 075
    Serial number: 20170826500580
    ODX name: EV_SMLSVALEOMQB
    ODX version: 001015
    Long coding: 1410
    Trouble codes:
17 Dashboard
    System description: KOMBI
    Software number: 5E0920950F
    Software version: 0310
    Hardware number: 5E0920950F
    Hardware version: 303
    ODX name: EV_DashBoardVDDMQBAB
    ODX version: 009060
    Long coding: 27AD02082980860001887B011001000000000000
    Trouble codes:
19 Gateway
    System description: GW MQB High
    Software number: 3Q0907530G
    Software version: 4303
    Hardware number: 3Q0907530C
    Hardware version: 433
    Serial number: 0006646371
    ODX name: EV_GatewNF
    ODX version: 013023
    Long coding: 030100047F085700EB00024A1C0F00010001070000000000000000000000
    Subsystems:
        System description: J367-BDMConti
        Software version: 1050
        Hardware version: H03
        Serial number: 7588600000170828067D
        System description: E221__MFL-PR6
        Software version: 0160
        Hardware version: H02
        Serial number: 000000000C1816180817
    Trouble codes:
20 High Beam Assistance
    System description: FLA
    Software number: 3G0857511G
    Software version: 0003
    Hardware number: 3G0857511G
    ODX name: EV_HighBeamAssisAU33X
    ODX version: 001017
    Long coding: 0404010700000100000000
    Trouble codes:
42 Driver Door
    System description: TSG FS
    Software number: 5Q4959593E
    Software version: 0032
    Hardware number: 5Q4959593B
    Hardware version: 011
    Serial number: 0000274068925
    ODX name: EV_DCUDriveSideEWMAXCONT
    ODX version: 006001
    Long coding: 00110022D001040000001100
    Subsystems:
        System description: FOND_FHSG_DRV
        Software version: 0007
        Serial number: 00000000000015935588
        Long coding: 1D0200
    Trouble codes:
44 Steering Assistance
    System description: EPS_MQB_ZFLS
    Software number: 5Q0909144T
    Software version: 1072
    Hardware number: 5Q0909144R
    Hardware version: 129
    ODX name: EV_SteerAssisMQB
    ODX version: 013144
    Long coding: 8107
    Trouble codes:
4B Multifunction Module
    System description: FCM MQB Low
    Software number: 3Q0907338
    Software version: 0286
    Hardware number: 3Q0907338
    Hardware version: 002
    Serial number: 29081710801494
    ODX name: EV_MultiModulContiVW48X
    ODX version: 001010
    Long coding: 000000070100046600003D01010000000000000000000000000000000000
    Trouble codes:
52 Passenger Door
    System description: TSG BFS
    Software number: 5Q4959592E
    Hardware number: 5Q4959592B
    Serial number: 0000272554428
    ODX name: EV_DCUPasseSideEWMAXCONT
    ODX version: 006001
    Subsystems:
        System description: FOND_FHSG_PSG
        Serial number: 00000000000015998943
        Long coding: 050200
    Trouble codes:
5F Multimedia
    System description: MU-S-ND-ER
    Software number: 5Q0035874C
    Software version: 0456
    Hardware number: 5Q0035874C
    Hardware version: H41
    Serial number: SKZAZ2T5337681
    ODX name: EV_MUStd4CTSAT
    ODX version: 001022
    Long coding: 03730101FF00000051111201008800002F0208C601200500CF
    Subsystems:
        System description: ABT_Std-2_Nav
        Software version: 8130
        Hardware version: H50
        Serial number: SKZ6ZHT1871718
        System description: ECE DL2 19/20
        Software version: 1115
        Hardware version: ---
        Serial number: --------------------
    Trouble codes:
76 Parking Assistance
    System description: PDC 4 Kanal
    Software number: 5QA919283B
    Software version: 0044
    Hardware number: 5QA919283
    Hardware version: H07
    Serial number: 00030841961722901935
    ODX name: EV_EPHVA14AU3700000
    ODX version: 009033
    Long coding: 0601050011
    Trouble codes:
D6 LED Module Left
    System description: LED1L
    Software number: 7P5941591AD
    Software version: 0005
    Hardware number: 7P5941591A
    Hardware version: H06
    ODX name: EV_LED_PLUS_L_KEBODAVW416
    ODX version: 001003
    Trouble codes:
D7 LED Module Right
    System description: LED1R
    ODX name: EV_LED_PLUS_R_KEBODAVW416
    ODX version: 001003
    Trouble codes:
These are 4b:
  Reveal hidden contents
Grouped stuff
I've changed that option to 'not active'. Mine is not dynamic LED headlight, isn't it? So it shouldn't be on anyways. whatabout citylight, highway light, Eco mode etc. I don't what value were there. but I remembered changing and enabling lots of function.
I'm not sure, but I think that AFS refers to Xenon lights which are of the projector type and city light and highway light are 2 of the various modes that AFS provide and are automatically selected by the vehicle's speed and Eco mode is a mode that adapts the throttle response to a more gentle style of acceleration. You might the answers whether your car has these features or not in the owner's manual in relation to what is fitted to your car?
@langers2kthe fault keeps coming back and they can be deleted after some time . I don't think they are related with temperature. I saw other time temperature was higher and there were no faults after scanning.
Another thing is, when I was checking my scan back up, i saw i had these faults June 2022. So, it means, they are not occuring because of me being changing the codes/options or so on.
They could be generic fault.
This is real temperatures of my low beam..
Edited by automass
No more 'low beam light bulbs' fault code for ages. so i think it fixes itself. Battery is performing super good. let's see how long it takes to give me problem. last one lasted 1year 4 months.
So this thread can be marked as solved. thanks to everyone.
